Question about Garden
Poulanpro 450E brand new ..put together...added gas...and oil ...primed 3 times..won't start ...the manual is not any help
  • 87 Answers
SOURCE: Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
Posted on Apr 09, 2009
  • 398 Answers
SOURCE: Husqvarna 65021 RS lawn mower, > 1 year old will not start
yea i think you scratched the cylinder. if there is not oil at any point then the engine will damage itself. and it wont have good compression. unless you want to attempt to rebuild the engine i would scrap it.
Posted on Apr 10, 2009
  • 2002 Answers
SOURCE: mower starts w/ priming but stops after 1-2 seconds. Air filter, gas, oil, spark plug are new
Remove your fuel filter (in the tank usually) and, replace it
Posted on May 20, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
SOURCE: Yardman 6.5 HP XL 21'' CUT S/N#D06786CN
See if it will start with a little splash of fuel down the carb.
If it starts for a second you probably have a plugged main jet.
The mowers collect a little bit of fuel in the bottom of the carb and then water comes along and it makes rust and gunk and turns the brass stuff all green. You remove the main jet and clean the two holes on the bottom and the little tiny hole at the top of the threads *(you should wire brush the threads and get a tiny piece of wire strand to clean this jet.)
I know you ran the mower till it ran out of gas....but that was only till it ran out of enough gas to fuel the main jet. There was still fuel residue in the fuel line and the bowl.
This should be a fast fix though. Good luck and be careful!
Posted on Jul 19, 2010
Brand new Echo gt-225 trimmer wont start. What could be the issue?
brand new did you put gas oil mix in it?? did you follow the exact starting instructions on it? newer one seem to need to bne primed like 10 times and the throttle held open when pulling the starter rope. choke on??
Jun 25, 2017 | Echo Garden
Put new gas and new oil in and tried to start. Would stall in few seconds when could start. There is fluid dripping from the filter area
Hi Anonymouse:
I'd be checking to make sure that the correct fluid in the correct amount was added to the correct place.
Start with the oil. Check the dipstick or indicator level. Too much oil will stop the engine. Sometimes gas get accidently put in the oil filler if an inexperienced person is helping with the maintenance.
Gas.......... Make sure that oil was not accidently added to the gas tank. Drain the carb and put fresh gas in the gas tank.
Spark plug.;.... pull and check for fouling. Replace if not really clean. Check for hot blue spark before re-installing.
This should get you back digging up the garden very soon.
May 15, 2015 | Garden
How do I start my Mastercraft snowblower
check gas and oil
check blower housing (round part) for ice and snow ( clear if needed)
put gas and choke on full
prime 3 times pull cord or hit electric start
repeat if it doesnt start with priming 3 more times
Jan 03, 2015 | Garden
Had the pressure bypass valve malfunction on my 2.5 jeep put new oil pump in and with 45lbs. Oil pressure motor still sounds dry of oil,what gives?
it's not priming.
that grease trick helps.
is this some china pump off fleabay or a real jeep pump..???
did you do the below.:
1: the grease sure. and then prime the filter and the gallery behind the
2: With fuel and spark defeated, and spark plugs removed then with pressure gauge attached to sender port, did you crank it to get max pressure (my guess is this is the step you are posting on.)
i never start any engine, (after majors) unless i get #2 to work first the number 3, which is top end oil checks.
the pump is no priming.
In pro shops they make up a priming tool. so new engines are never
started, 1st time dry, ever.
one way is just a tank full of oil and shop air, and 2 valve.
maybe the new pumps relieve valve is stuck open, fully.
i rebuild my own classic engines, after all that work !!! i never
ever, skip these steps.
and for 100% sure, good pressure, and top end oiling on any major work.
one of the top brand pump makers. VIDEO
Feb 17, 2014 | 2002 Jeep Wrangler
Let my 450E husquarna run out of oil now the chain wont turn
Remove the bar with the chain and with gloves on see if you can pull the chain up out of the bar. If it comes out oil it up, put it back together, ad try running it.
Oct 30, 2013 | Garden
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Brand new husqvarna 235 chainsaw will not start
is the kill switch on?check the spark plug it could have had the wire fall off in shipping
May 24, 2012 | Husqvarna Forest & Garden #952802239 235E...
Bought a Poulan Wild Thing 18" gas chainsaw (P4018WT) secondhand from someone who only bought it to cut down 3 trees. It will not start. I know that it works, as the guy started it up and showed me how...
Don't prime it 6 times.
Prime it once and try starting. Keep trying with one prime.
If that doesn't work, let it sit for a bit. And then prime it two times and try starting again.
If that doesn't work, try priming 3 times.
Then try half-choke with one pull only, and then move choke to run for the second pull.
The saw might have an on-off button
Oct 15, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Brand new 550! push red pump button 3-4 times... pull handle..mower starts up then dies. Will not continue to run..
Sounds like wet fuel! The priming puts enough gas in to start it but the running circuit does not.
Check your gas can for a layer of water on the bottom of it. If it has a lot of water in it you should dispose of this fuel at a gas station that collects used oil and gas. Drain the mower and take that gas away too.
Put in fresh gas from a known clean and dry source.
Let me know what you find ok?
Jun 29, 2010 | Craftsman 550 Torque 22 in Deck 2n1 Side...
Will not start - brand new
i bought a new dirtbike as a kid n same turned out ,it needed to be a synthedic oil in the mix.try seeing for spark to begin with by putting sparkplug in the wire n touching diode to the engine block while pulling the cord.thats a good starting point to diagnosing your problem.maybe try warming it up in the house then try starting it with no choke needed.the saws i ve used needed you to give it throttle after you pull,n no throttle with choke.
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
