Question about Acer AL1713 17" LCD Monitor
Acer AL 1713
I have the same problem! At 20 attempts off turning off and on, i get it to work stable as long as i am actively working. Sleep mode, reboot, screensaver all make me repeat the process, how to fix? It can't be that major, i hope:-)
manythanks
    Problem Solver:
  • 7 Answers
Capacitors C6 and C22 usually are the problem on this model. They are 220uf at 25volts. you may also notice that resistor labeled R1 may be discolored or a little "toasty" so I generally replace it while i have it apart. It's a 10ohm 1/4 watt resistor. I hope this helps.
Posted on Feb 17, 2010
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
Acer aspire sleep mode
Hi ,
it seems that your desktop is not posting . You can take out the cover of your desktop and try reseating all of the RAMs or memory module.
Hope it works.
Thank you.
Dennis
Sep 08, 2014 | Acer Aspire Computers & Internet
No sleep mode on acer monitor
This is annoying, but try to go back on factory default setup.
Apr 15, 2014 | Acer Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Dec 11, 2009 | Computers & Internet
Wont recover from sleep mode after depleted battery
plug out the batter and give the AC. turn it up. any light? if you dont have you have a problem with Mainboard that doesnt let the electircitiy goes in.
of course i am assuming your adapter is working :)
May 30, 2009 | Acer Computers & Internet
GETTING A NO SIGNAL MESSAGE FROM MONITOR
Hey,
Press a few buttons on the keyboard incase the computer is in sleep mode.
If you still don't get picture at all, the issue is with the computer, please test the screen on another computer to see if the problem persist there, if it works perfectly on the other computer then theres a problem on the computer and I suggest you get someone to look at it.
Thanks,
Ekse
Feb 15, 2009 | Acer AL2216WBD LCD Monitor
How do I wake up my laptop from sleep mode?
To get out of sleep mode you should hit any key, move the mouse, open the lcd. To go into sleep Fn+F4
Jan 28, 2009 | Acer Aspire 3680 Laptop
Acer AL1713 17" LCD Monitor Logo
560 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
