Question about Refrigerators
I have a sedu revolution 4000i, the covering on the back got lost during travel. I need to buy replacement cover, because the hair gets caught in the fan.
kimbo322
  • 10 Answers
SOURCE: Tension has thread caught in it.
Hope this helps. In the order I would recommend:
  1. "Floss" the tension disks - this is nothing more than running a heavy thread (12 weight or upholstery) through the thread path, grasping the thread at the spool and the end that is through the needle and "flossing" just like you would your teeth - slide the thread back and forth through the disks/thread path. This will often-times pull through whatever is stuck!
  2. If the thread is more deeply tangled than "flossing" will fix, you CAN remove the top of the machine to better see it. I would, however, recommend you take the machine to a Pfaff-trained tech if this is the case - things that can be damaged if you're not trained on the machine. However, if you're wanting to give it a try (the thread may be easily visible and easy to get to):
    • Remove the stitch lid - there are little metal clips at the base of the lid that you can push outwards to remove the lid - can't get the top off without removing lid.
    • In the well of the machine top are a few screws (2 if I'm remembering correctly). The screws are star-shaped as opposed to Phillips or Flat - special screwdriver is required. Just make sure you don't remove the screw that's holding the bobbin-winding mechanism on.
    • Once the screws are loosened, you'll have to maneuver the top out of it's position - this requires a little wiggling but is not impossible (just impossible to describe how to wiggle it!!)
    • Turn machine OFF and UNPLUG it. Too many electrical connection points you will be working around to take a chance!
    • VERY CAREFULLY... turn the handwheel towards you (never turn backwards) until you are able to view the entire race/thread path. If you can EASILY remove the stuck thread, go ahead and do it. If you have to do too much pulling and tugging, be VERY careful - if the thread is wrapped around the check spring, you may bend/break it.
Again - hope this helps!
Happy sewing,
Kim
Posted on May 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Battery Cover
Here is a link to the order form for the battery cover - or you can call VTech directly. The part is free, but there is a $5.50 shipping charge:
http://www.vtechkids.com/_f/_pw/_replacementParts/V.Smile.pdf
-Tha Mp3 Doctor
Posted on Jan 04, 2009
SOURCE: lost battery cover
You can call the company and give them the model number MX-350 and they sell for around $4.00 a piece. I bought 2 in case I lost another one.
Call Osiris Universal remote @ 914-835-4484 or e-mail to repairs@universalremote.com
Hope this helps,
Webb
Posted on Apr 24, 2009
SOURCE: need new replacement cover
I have a boys and need a girls cover can trade?
Posted on Jun 05, 2009
  • 7 Answers
SOURCE: lost cover for right side mirror. black color.
I would go strait to the dealer for this part.It will cost you a few more dollars than some online store but it will be an exact fit the first time and retain the value of the vehichle by replacing the missing part with a OEM part.
Posted on Jul 12, 2009
Lost back cover sharp part ccabbb693we01 (model lc40le820 or 810
Hi - I also lost same back cover(ccabbb693we01) during cleanup. Let me know or I will let you know if we find it. I just ordered one on special order,but they cannot assure me to get it.
Not long ago,I ordered at two different place on special order but I was told after close two months (part not availlable).
Today,poor service is not surprising from manufactures when finding parts.Waiting two months to know if is is availlable is ridiculous
dtelectronic47@gmail.com
Domenico Toto
Mar 08, 2014 | Sharp LC40LE810 40 in LCD TV
How do you adjust the blades so that the hair won't get caught in the Oster 76097-440?
take off the clipper blade cover. 1 phielphs head screew. metal plate is about 11/2 ins. by 1" metal chrome cover. clean all hair out. your clipper came with a small plastic tube of oil. 1 or 2 drops no more put on cutter. any house hold oil will work
Aug 05, 2012 | Oster 76097-440
My CHI straightener has a GFI plug that needs replaced.
look up leviton 16592 on amazon or something similar. I just had to replace this on a sedu iron. About $20, but cheaper than a new iron.
41x1vrxnoql._sl500_sl135_.jpgtransparent-pixel._v192551059_.gif Leviton 16592
Jan 23, 2011 | Chi Nano Digital Ceramic Flat Iron 1.25...
The brush is clean and spinning but it isnt picking up anything and just pushing pet hair around.
You mentioned pet hair. Remove the brush cover and check for a plug (possibly pet hair). Sounds as though you have a plug somewhere and it's not allow the suction to pull it through. Also check your filter and clean or replace as necessary. Hint; Never let you container get over half full, it reduces the suction.
Nov 02, 2010 | Bissell 6591 Power Trak Revolution Bagless...
Middle column between doors is very hot
You need to pull the refrig out and remove the back panel , covering the compressor and fan . If the fan is not running , check for something caught in the fan blade . If nothing is found then replace the fan motor . Also make sure the coils at the bottom in front , are clean of dust , lint , pet hair , etc .
The fan , helps keep the compressor and the coils cool , including the ones behind the middle column .
Oct 20, 2009 | Kenmore 57029 Side by Side Refrigerator
The bumper cover has cracked, due to a parking lot wheel stopper getting caught underneath. What is the most afforable way to replace the bumper cover?
What you need is called a LOWER FRONT VALANCE.
You can get one from a VW dealer or search the web to buy.
Easy to install. I got mine from ebay for $20.00
Sep 24, 2009 | 2002 Volkswagen Jetta TDI
Broken screen on lg dare Broken touch screen. can it be replaced? got my phone wet for a second. dried it off. everything works, but my touch screen will not respond on the left side of the phone. water...
ive had a similar problem... but what i did is i looked at what the insurance does cover... since it doesnt cover water damage.. defect the phone in some way that the insurance will cover. its only if you're in desperate need. there is no way to fix water damage... but i know PLENTY of tricks to soak water out of the phone
May 30, 2009 | LG Dare VX9700 Cell Phone
Need new replacement cover
you should be able to call Evenflo's ParentLink Consumer Resource Center at (800) 233-5921. Give them your model # and month/year made and they can assist.
Jan 02, 2009 | Evenflo Aura Traditions Travel System...
Dog Hair under protective coating on monitor
get your Dell manual out and look in the index for lcd cover. It should tell you how to take it off and maintain it. If things get behind it it should be removable. Also www.dell.com is very informative with their support group.
Sep 13, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
