Question about Targus Computers & Internet
Need wiring diagram for output cable of an Targus APM12US-1 DC Auto/Air Adapter
The DC molded output cable has an open connection where it goes into the PS. I have removed the cable, stripped the cable back past the broken wire and want to re-attach the cable. I need to know what color wire go to which solder cups.
jamesmac
  • 71 Answers
SOURCE: wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Posted on Sep 09, 2008
SOURCE: hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Posted on Nov 29, 2008
  • 21 Answers
SOURCE: wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
Posted on Jul 11, 2009
atocrxr
  • 135 Answers
SOURCE: air conditioner wiring diagrams
What brand of A/C is it? Are you looking for the thermostat wiring? Different Brands use different wiring, but the usual is as follows:
R terminal at furnace is 24 volt Hot
W is the control for the heating cycle
G is used to start the furnace blower
Y is used to start the outdoor A/C
B or X depending on Brand is the 24 volt common
Yellow and B or blue is the other wire that goes to the outdoor unit
If you want more info, I need Brand, and type of unit, gas furnace and A/C, electric furnace and A/C, or is it a heat pump for the outdoor unit?
Hope this helps./
Sincerely,
Paul Gibson
Posted on Apr 01, 2010
  • 417 Answers
SOURCE: Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Posted on Apr 15, 2010
Acer aspire
Technically, Yes. If there is damage to the wires but you know the AC-DC adapter is still good. There is a small single sided PCB inside the adapter that houses the transformer and step down/rectification circuit. There are two wires for the input (AC from wall which are hot and neutral) and two for the output which is your Ground and +18-19V (can't remember that particular voltage off the top of my head.) If you need to replace the plug that goes to the wall, check your plug type (the one that goes into the adapter) and order/buy a new one. That can be replaced with any plug that fits a desktop power supply. If you need to replace the plug that goes into the computer THEN you'll have to open the Adapter box. The two wires coming out of the board into the cable can be de-soldered. Just make sure you purchase the correct size/type tip (plug) for your computer and solder the positive and negative in where you removed the ones attached to the damaged cable.
Once you have soldered your new cable onto the motherboard, use a good epoxy to seal the box back together. They are not "user servicable" therefore, there are no easy to snap on/off clips, you will have to use a good adhesive. Also, TEST YOUR OUTPUT BEFORE PUTTING IT IN YOUR COMPUTER!!! Read the bottom of the Adapter and see whether the center of the plug is positive or ground, connect your DC voltmeter accordingly and make sure that the output voltage matches what the adapter says. It may be .2-.3V higher than what the adapter says because there is no load (your laptop) on the output but as long as it's no further off than that, you're good!
Good Luck!
PS: There are capacitors in the adapter circuit that can hold a VERY large charge and potentially hurt or kill you! You can also completely destroy your power adapter if you do not know what you are doing. Find a couple of youtube videos on the subject, there's tons of 'em. I am not responsible for anything that you attempt without having the proper skillset. For anyone handy with a soldering iron and familiar with electrical circuits, it's an easy fix.
Aug 18, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 5580 Notebook
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
I have the targus model APM65US DC auto/air adaptor and various tips. Which tip/connector is compatible with a Dell Inspiron miniu 10. Several look like the right size: #s 102, 104, 206, and 207. Which...
I know this sounds odd but use whichever one is the best fit and works. Also I suggest that you compare them carefully with the original noting differences in length, diameter and construction.
I think you will find that one fits better than the others.If it works and you don't have to push too hard to locate it, and it stays in firmly and connects OK then it will be fine.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Targus APM65US Auto/Airline/AC Adapter -...
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
04 zx6r code 15
some info from the manual (636) fault code 15. hope it helps??
Atmo- Absolute Atmospheric If the atmospheric pressure sensor system fails
15
spheric Pressure (the signal is out of the usable range, wiring short
Pressure Pa =100 mmHg - 900 or open), the ECU sets Pa at 760 mmHg (the
Sensor mmHg standard atmospheric pressure).
Atmospheric Pressure Sensor (Service Code 15)
Input Voltage Inspection
NOTE
o Be sure the battery is fully charged.
o The inspection is the same as "Input Voltage Inspection"
of the throttle sensor and the inlet air pressure sensor.
• Turn the ignition switch OFF.
• Remove the ECU (see this chapter). Do not disconnect
the ECU connectors.
• Connect a digital voltmeter [A] to the connector (8), with
the needle adapter set.
Special Tool· Needle Adapter Set: 57001-1457
Atmospheric Pressure Sensor Input Voltage
Connections to ECU
Meter (+) --+ BL lead (terminal 1)
Meter (-) --+ BRISK lead (terminal 14)
• Measure the input voltage with the engine stopped, and
with the connectors joined.
• Turn the ignition switch ON.
Input Voltage at ECU
Standard: 4.75 - 5.25 V DC
*If the reading of input voltage is less than the standard
range, check the ECU for its ground, and power supply
(see this chapter). If the ground and power supply are
good, replace the ECU.
*If the reading is within the standard range, remove the
seat cover, and check the input voltage again at the sensor
connector. *Remove the air cleaner housing (see Air Cleaner Housing
Removal).
• Disconnect the atmospheric pressure sensor connector
and connect the harness adapter [AJ between the main
harness connector and pressure sensor connector.
• Connect a digital meter to the harness adapter leads.
[8] Atmospheric Pressure Sensor
Special Tool - Throttle Sensor Harness Adapter #2:
57001-1408
Connections to Sensor
Meter (+) -l' BL lead [C]
Meter (-) -+ BRISK lead [OJ
with the connector joined.
Input Voltage at Sensor Connector
*If the reading is out of the standard range, check the
wiring (see wiring diagram in this section).
*11 the reading is good, the input voltage is normal. Check
the output voltage.
Output Voltage Inspection =
• Measure the output voltage at the ECU in the same way °0
as input voltage inspection. Note the following. 8 .~ (j')
Digital Meter (AI ®~O ECU Connector IS]
Atmospheric Pressure Sensor Output Voltage ' 11 .
Meter (+) ~ GfW lead (terminal 4)
Meter (-) -+ BRiSK lead (termina114) tC·lInn, C ,
Output Voltage
Usable Range: 3.80 - 4.20 V DC at the standard
atmospheric pressure (101.32 kPa, 76
cmHg abs.)
NOTE
o The output voltage changes according to the local at·
mosphen'c pressure.
D The atmospheric sensor output voltage is based on
a nearly perfect vacuum in the smaJl chamber of the
sensor. So, the sensor indicates absolute atmospheric
pressure.
*If the output voltage is within the usable range, check the
ECU for its ground, and power supply (see this chapter). If
the ground and power supply are good, replace the ECU.
*If the output voltage is far out of the usable range, remove
the fuel tank, and check the output voltage at the sensor
connector [A] (when the wiring is open, the output voltage
is about 1.8 V).
• Connect a digital meter [A] to the harness adapter leads.
[8) Atmospheric Pressure Sensor
Special Tool· Throttle Sensor Harness Adapter #2:
57001-1408
Meter (+) -+ GfW lead [C]
Meter (-) -+ BRlBK lead [OJ
Output Voltage at Sensor
cmHg abs)
*If the output voltage is normal, check the wiring for continuity
(see next diagram). *If the output voltage is out of the usable range, replace
the sensor.
Apr 17, 2009 | 2001 kawasaki ZX-6R Ninja
Hi; I Have a Dell XPS 1530 which is dull if I do not have it plugged in. I have three Targus power cords and cannot use any of them. The one that has the S35 tip fits, but only engaged...
I am showing the AC adpater specifications as:
Input Voltage Range: AC 100V - 240V
Output Voltage: DC 19.5V
Output Current: 4.62A
Power: 90 Watt
Does your adapter meet those specifications?
Although I am a proponent of Targus products, possibly purchasing an OEM adapter may solve the problem. We have successfully purchased ones available from reputible vendors on eBay at a discount.
Have you checked to always show the battery status in the system tray so that you can verify when the AC adapter is actually charging versus an intermittent connection or malfunctioning power socket?
Oct 22, 2008 | Computers & Internet
ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Sep 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Computers & Internet Logo
76 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
