Question about Cell Phones
How to load voice mail - Cell Phones
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
Mismatch of application settings no voice mail. how to fix
some phones have virtual voice mail...which means you must syc it with the service voice mail ... if voice mail is pass word protected ...you must program the voice mail password and information into the virtual voice mail or it will not retrieve messages or give you notification of incoming voice mail.. The directions they give you for this is really asinine and hard to understand. Call your service provider they will be able to help you.
Mar 11, 2015 | LG G2 Black Smartphone - Verizon Wireless...
Lost the manual and need to record a new voice mail message
to leave a voice mail message on the Samsung Prostar;
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
Jan 22, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
How do i setup my N73 voicemail
sir the voice mail box is a network service to which you may need to subscribe .for more information ,contact your service provider .to call your voice mail box ,press and hold 1 .........to edit your voice mail box number ,select menu >messaging >voice messages >voice mail box select the following settings to setup the voice mail
Nov 23, 2010 | Nokia N73 Cellular Phone
How do I access my voice mail?
put your voice mail number in voice mail settings or you can dial directly your vc number to listen your voice mails,if you dont know your voice mail number then ask your network operator for number
Aug 29, 2010 | Cell Phones
How do I get an extension on the main console to go directly to voice mail.
Hello Friend,
Click on this link(it may take few minutes to load according to Connection speed) and you will get Helping Guide for your Product...If you want to get Feature Codes ,then go to Page 9.OR to Call directly to another User's Voice mail/Transfer a Call directly to another User's Voice mail-See Page 13 for Detailed Information.
  • Press programmed Direct Voice Mail Button/Press Feature Button and Select Direct VM[DrcVM] OR Dial 56
  • Dial the Extension whose voice mail you want to Call/Transfer a Call;you can Use Programmed AUTO DIAL Button OR a Directory Listing too(See Page 11,14)
There is Possible to just Click on the Index data as you need... Hope This Lead you better Conclusion....Thanks for Contacting FixYa...
May 27, 2010 | Lucent Merlin Legend MLX-20L Phone
RCA Digital voice recorder RP5020A
This is the manual for the RP5020 and RP5025. Hope this helps!
Jan 24, 2008 | RCA RP5020 Digital Voice Recorder
Voice mail notification to cell phone
This is a phone system phone. What you are looking for would be a feature of your voice mail that is connected to the phone system. "Handsfree Speakerphone- 3-Line Back Lit display and 24-Line Keys. Compatible with KXTDA200 and KXTDA100 Systems. " Sounds like you either have a KX-TDA200 or KX-TDA100 phone system. Usually voice mail is an optional feature and has a separate part number. You could also have voice mail service through your phone service provider (like Verizon) Do you have any user guides for your voice mail or one for your phone that covers voice mail features? If not, the first step is to find out for sure what you have for a voice mail. If you have a working message waiting light on the phone it would be an in-house voice mail connected to the system.
Sep 13, 2007 | Panasonic KX-T7633 Corded Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
