Question about Garden
Brand new out ot box 21" mower won't start...put in oil..and gas...primed ...and won't start...ordered on line
  • 2,160 Answers
Sometimes new mowers are shipped without spark plug wire attached to spark plug.
Posted on May 08, 2017
    Top Expert:
  • Garden Master
  • 34,170 Answers
The mower may be defective as delivered.
Brand new mower out of the box, got it together, primed, turns over but shuts right off like it's not getting gas. Is there a shut off switch or something?
You don't say what kind. I know Honda's mowers have a fuel shut off on some of them. Check the gas line to see if it's clear
May 02, 2015 | Garden
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Small engine won't start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Feb 09, 2012 | Garden
Ai put oil/gas mixture in tank...drained tank put correct gas and cleaned air filter..will only start after prime but only for a second
You've probably plugged the carburetor up with oil. It'll need a good cleaning with carb cleaner. If you don't know how, then I'd recommend a professional to do the job. Best of luck to you.
James
Aug 20, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I prime it; and it starts right up. Then, it stalls out, after a second ot two. Its a new lawn mower; and there is plenty gas in it.
Check your gas can. If you put dirty fuel in it, it will block the jets in the carburetor, preventing the engine from getting enough fuel. If you have a dirty gas can, you now will need to clean the carburetor jet.
Jul 25, 2011 | Poulan "" Push Mower
Yardman 6.5 HP XL 21'' CUT S/N#D06786CN
See if it will start with a little splash of fuel down the carb.
If it starts for a second you probably have a plugged main jet.
The mowers collect a little bit of fuel in the bottom of the carb and then water comes along and it makes rust and gunk and turns the brass stuff all green. You remove the main jet and clean the two holes on the bottom and the little tiny hole at the top of the threads *(you should wire brush the threads and get a tiny piece of wire strand to clean this jet.)
I know you ran the mower till it ran out of gas....but that was only till it ran out of enough gas to fuel the main jet. There was still fuel residue in the fuel line and the bowl.
This should be a fast fix though. Good luck and be careful!
Jul 18, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Brand new 550! push red pump button 3-4 times... pull handle..mower starts up then dies. Will not continue to run..
Sounds like wet fuel! The priming puts enough gas in to start it but the running circuit does not.
Check your gas can for a layer of water on the bottom of it. If it has a lot of water in it you should dispose of this fuel at a gas station that collects used oil and gas. Drain the mower and take that gas away too.
Put in fresh gas from a known clean and dry source.
Let me know what you find ok?
Jun 29, 2010 | Craftsman 550 Torque 22 in Deck 2n1 Side...
My brand new Briggs and Stratton Lawnboy won't start!!!
if you play with it u will void the warrantee. call the dealer u got it from
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
