Question about Boating
Need wiring diagram for factory installed wiring on 2015 Mako 17 foot skiff with center console; wiring on back of factory center console switch arrays have become loss and some disconnected.
2 Suggested Answers
  • 552 Answers
SOURCE: I have a 2015 Mako 17 ft pro skiff..... I've taken
warranty service
Posted on Dec 17, 2014
Replacing rav4 factorie sterio 2004 with a new 2015 jvc sterio system
Use a harness adapter if you haven't cut the factory wiring plug in the car. If you have go to www.modifiedlife.com. they have an excellent resource page with wiring diagrams
Jul 30, 2016 | Cars & Trucks
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
Dec 30, 2014 | Vehicle Parts & Accessories
Looking for the wiring diagram for the power windows in a 1974 model 4.2 Mercedes Benz, with specific detail about the center console switches. Thank you!!!
we have no such diagrams, this detailed info will only be found in a factory service manual, u can try ebay for used one or a manual on a CD to save money, u may also go to www.faxon.com for used factory service manuals
Oct 17, 2010 | Mercedes-Benz 400-Class Cars & Trucks
Radio installation without factory wiring harness in 1983 jeep CJ 7. Radio will be installed in secure center center console. I checked under the dash and could not locate a factory harness and not sure...
ok its easy, first see the stereo installation diagram, but i think its have spare wire harness, try to find it. inlay your wire in secured area, dont forget to install fuse in acc and in hot at all time(constant 12V)
Jun 18, 2010 | 1983 Jeep CJ7
Install alarm system
Battery- RED RED (+) IGNITION SWITCH HARNESS (2 CONST WIRES)
Ignition 1- PINK (+) IGNITION SWITCH HARNESS
Starter 1- YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger- WHITE (-) SMALL HARNESS BELOW ASHTRAY
Trunk Trigger- RED/BLACK (-) AT TRUNK LIGHT
Parking Lights- BROWN (+) BEHIND FUSEBOX UNDER CONSOLE OR SWITCH
Power Unlock- WHITE (+) POSITIVE TRIGGER OR DRIVERS KICK PANEL
PowerLock- LIGHT BLUE (+) IN CENTER CONSOLE "BEHIND FUSEBOX"
Apr 12, 2009 | Vehicle Parts & Accessories
Need diagram for 2007 escape audiophile
if it is the wiring diagram for the Escape you need, here it is:
12 VOLT CONSTANT Connect to BATTERY ONLY STARTER TAN/LIGHT BLUE (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 LIGHT GREEN/PURPLE (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLACK/LIGHT GREEN (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) WHITE/BLACK (-) @ SJB, Connector E, Pin 4, See NOTE *1 PARKING LIGHTS ( + ) BROWN (+) @ SJB, Connector C, Pin 19, See NOTE *1 POWER LOCK PINK/WHITE (1-Wire System) See NOTE *2 @ SJB, Connector D, Pin 22, See NOTE *1 POWER UNLOCK Same wire, See NOTE *2 See DIAGRAMS DOOR TRIGGER PINK (-) @ SJB, Connector C, Pin 28, See NOTE *1 DOMELIGHT SUPERVISION USE DOOR TRIGGER TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN YELLOW/LIGHT GREEN (-) @ SJB, Connector A, Pin 14, See NOTE *1 TACH NOT RED or WHITE/RED @ IGNITION COIL or FUEL INJECTOR WAIT TO START LIGHT N/A BRAKE LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DARK BLUE/LIGHT GREEN (-) @ SJB, Connector D, Pin 3, See NOTE *1 ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER EXTRA INFORMATION NOTE *1 The SJB (Smart Junction Block) is the FUSE/RELAY BOX on the PASSENGER SIDE of the CENTER CONSOLE. NOTE *2 This vehicle uses a 1-Wire Door Locking System, LOCK requires a (-)Negative thru a 1000 Ohm Resistor and UNLOCK requires a straight (-)Negative
Jan 06, 2009 | 2005 Ford Escape
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
