Question about Troy Garden
What year was my troy built briggs and Stratton generator built. model 01919 and serial # 1012074373
mowerman1857
  • 389 Answers
SOURCE: white smoke and oil spewing out of troy built
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Posted on Sep 19, 2009
jyackle5
  • 8197 Answers
SOURCE: I NEED A DIAGRAM OF A BRIGGS AND STRATTON TROY
Go to link below for a parts break down for your tiller. Starts on page 23
http://dl.owneriq.net/c/c23c1d7c-74ff-4347-b31e-a0ee0462b35e.pdf
Posted on Apr 17, 2010
  • 1383 Answers
SOURCE: What type oil do I
For most Briggs engines / from the Briggs web site :
Oil Recommendation
  • SAE 30 40° F and higher (5° C and higher) is good for all purpose use above 40° F, use below 40° F will cause hard starting.
  • 10W-30 0 to 100° F (-18 to 38° C) is better for varying temperature conditions. This grade of oil improves cold weather starting, but may increase oil consumption at 80° F(27° C) or higher.
  • Synthetic 5W-30 -20 to 120° F (-30 to 40° C) provides the best protection at all temperatures as well as improved starting with less oil consumption.
  • 5W-30 40° F and below (5° C and below) is recommended for winter use, and works best in cold conditions.
Type of oil to use
  • Use a high quality detergent oil classified "For Service SF, SG, SH, SJ" or higher.
  • Do not use special additives.
  • Choose a viscosity according to the table above.
2978e398c0ac447584fe192e2a57cfbc.ashx
50a40449f9a74cc9a5d6c460f40284d0.ashx
Back to Search Results
Posted on Jul 04, 2011
gir60
SOURCE: I have a Troy Built pressure washer model 020245-1
I need a gas tank for a 020245 Troy- bilt pressure washer 2200.
Posted on Apr 11, 2012
Valve adjustment on 23hp troy built mower
Model, Type and Code are required if this is a Briggs and Stratton engine. Thanks; George
Apr 21, 2013 | Briggs & Stratton Garden
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
What type oil do I nee4d for a 10hp ohv Mdl 01919 used on a troy built generator
Oil Recommendation
Type of oil to use
Jul 04, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
Where do i get a coil at?
Well, if Briggs and Stratton engine, then try briggs and stratton.
If Robin / Subaru engine, try there.
Write down the model type and serial numbers, then pay a visit to local small engine repair shop and have them order for you.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
Briggs and stratton engine #204412 type #0163e1
I found a parts list for model 204412 at http://www.buysmallengineparts.com/
Jun 30, 2008 | Computers & Internet
Garden Logo
22 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
