Question about Samsung Dryers
Samsung front load dryer flashing shirt?
Our dryer stopped working and there is a flashing shirt does anyone know what this means?
jsrock516
  • 5911 Answers
SOURCE: Error message "F5"?
F5 is a Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. If you are savvy enough to troubleshoot yourself, you can check the Water Temperature Sensor, Heating Element and Element Relay. You should also check connections to the Sensor, Heating Element and Relay. As far as servicing goes, Sears and Whirlpool have service contracts on these appliances as the Kenmore Elite and Whirlpool Duet are the same machine made by Whirlpool. I hope this helps you.
Posted on Sep 19, 2007
taran_2005
  • 10515 Answers
SOURCE: My kEnmore front load he2
F-28 refers to Communication Error.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
- Check connections of the CCU board within the housing.
- Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test
or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Note - The cost of CCU and MCU is more than $200 each. You cannot replace a part of CCU and MCU. The complete Set needs to be changed. If the Washer is more than 4 years ( which i assume, as this Error is usually after 4-5 Years ), it is better to Invest in new one than Repair.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 06, 2009
  • 105 Answers
SOURCE: press start on the samsung front loader j845 and
De means door error and the door lock needs replacing. the part number is DC64-00519B if your model number ends with AAG
Posted on Feb 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: i have a front load whirlpool washer and it keeps flashing f33 and won't work
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
ladiestch
  • 19 Answers
SOURCE: Flashing container light. what is this? Dryer
Try taking out the lint screen and scrubbing it well in the sink with hot water and a brush. If you havent cleaned out below the lint screen, get a vacuum and a crevice tool and remove any standing lint as well as cleaning the vent. Bosch lint screens clog easily especially if you are a big fabric softener user.
Posted on Nov 20, 2010
We have a samsung front load dryer and it stopped working showing a flashing shirt
Try unplugging the Samsung dryer for 5 minutes.If plug is hard to get to,switch off breaker to dryer,then flip back on after 5 mins.Hope this solves your problem !!
May 08, 2017 | Samsung Dryers
Nov 20, 2010 | Bosch Classixx WVF 2402 Front Load...
I am getting an error code "DC". What does that mean?
DC means: Unbalanced load prevented the washer from
spinning.
This happened to me when i was washing a single shirt (red shirt, first time washing so i did it seperately so it wouldnt bleed into other clothes)
So i set the washer to "drain", waited for the door to open, and wrung the shirt out by hand. Next load it worked properly.
Jan 16, 2009 | Maytag Neptune MAH9700 Front Load Washer
Dryers Logo
290 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
