Question about Samsung Dryers
We have a samsung front load dryer and it stopped working showing a flashing shirt
    Habit-Forming:
  • 143 Answers
Try unplugging the Samsung dryer for 5 minutes.If plug is hard to get to,switch off breaker to dryer,then flip back on after 5 mins.Hope this solves your problem !!
Posted on May 08, 2017
  • michael vanier May 08, 2017
    If the reset does not do the trick, You either have ab ad control board, or a thermal fuse inside the dryer has broken and would need to be replaced.
Tip
SENSOR DRY IN SAMSUNG DRYERS
As a tech, I'm constantly fielding questions about loads of clothes not drying properly in the larger Samsung dryers--and this tip can be used for a lot of dryers with the sensor-dry feature. Sensor drying uses a pair of metal strips located on the filter holder or on the back wall in the dryer. When wet clothes rub against the strips, this sends a signal to the main board which tells the dryer to keep going. Unless large loads are used, the consumer should use "timed dry". This is because smaller loads won't hit the sensor strips often enough and cause the computer to count down too rapidly. Also, consumers should try to make sure like items are placed with like items( shirts with shirts, pants with pants, towels with towels, etc) Thick clothing(jeans, heavy sweatshirts, etc.) usually will have damp spots like pockets due to the moisture not being able to contact the sensor strips--the technology is not 100%. Also, if there are problems with the timer starting to count down too rapidly all the time, and dryer sheets are used, the sensor strips may be coated with a waxy layer. Use some super fine emory cloth to polish the coating off of the sensor strips. You very well might find that the problem is solved and not have to initiate a service call!
on Sep 08, 2015 | Samsung Dryers
Why does my Kenmore front loading dryer which is only a year old shreds our clothes!
call sears and gripe about it seems I read about one that the fins were loose and they had to replace the outer drum the wet clothes put too much pressure on them and they flexed
Mar 09, 2015 | Kenmore Dryers
My whole family's clothes are shrinking. We purchased Whirlpool washer and dryer Jan 2013 front loaders. We have tried to use several different water temperatures and cycles. We have stopped using the...
call whirlpool sounds like your dryer is getting to hot for some reasons and giving you this problem. I don't dry my shirts and more I just hang them up on hanger to dry. the dryer seems to shrink the length of my shirts.
Aug 24, 2013 | Whirlpool Whirpool Energy Star Dishwasher...
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Kenmore he4t front loading dryer stopped working
did you clean the lint?
is the way the airflow goes not blocked with residue??
Mar 19, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
102 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
