Question about Light Garden
Kohler engine/cub cadet/oil light stays on-oil is full-===sputters and kills;;;;;is it an oil pressure problem or the oil pump?
4 Suggested Answers
  • 472 Answers
SOURCE: Kohler courge sv720-0010 on cub cadet
Posted on Oct 12, 2009
  • 986 Answers
SOURCE: Cub Cadet Riding Lawn Mover with Kohler Engine -
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
  • 112 Answers
SOURCE: Cub Cadet XT1 Kohler Engine Stall
Most likely your cap is not venting properly, replace the cap.
Posted on Sep 03, 2016
Testimonial: "I have tried that. Any other solutions?"
Cub cadet 4621 zx390 single cyl. oil comes out of dip stick tube where is breather located
Find your carburetor assembly. you have a rubber tube coming from that to your to your oil breather. you can also look up your parts manual using the same info you gave here. Cub cadet 4621 zx390. looks like a kohler engine.
Aug 29, 2017 | Cub Cadet Garden
Have a Cub Cadet Lt 1050 when you start it, continues to turn over and not start.
Check your oil. Most cub cadets use a kohler engine which will allow gasoline to drain into the crankcase and fill it with gas. The fuel must be shut off on kohlers which can cause unwanted flooding due to a stuck float. You may be surprised when you open the oil check and find gasoline coming out. If not, lightly sand the magneto and the flywheel to make sure you have a spark. If you do have a spark, it is most likely a gasoline issue caused by the flow being stuck in the bowl of the carburetor, causing a Kohler not to start
Sep 02, 2016 | Cub Cadet Garden
maybe bad sending unit most likely or bad oil pump
Jul 31, 2014 | Cub Cadet Garden
Oil light on ltx 1050 cmes on after starting engine but it's full of oil
oil light indicate oil PRESSURE not volume... replace the filter which may be blocking oil flow, and then see about replacing the oil pump
Jul 04, 2014 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
Oil light on cub cadet zero turn radium mower is flashing
could be oil pump pressure to low for that engine
May 25, 2013 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Cub Cadet Riding Lawn Mover with Kohler Engine - oil light stays on.
Aug 20, 2010 | Cub Cadet Garden
Garden Logo
Top Light Garden Experts
Dennis Key
Dennis Key
Are you a Light Garden Expert? Answer questions, earn points and help others
