Question about Dishwashers
I can't get my heat to run. As soon as I press the heat button, it starts flashing P1. Help!
2 Suggested Answers
  • 8 Answers
SOURCE: Loan Balance
Loan balance is the amount you are expecting to borrow, or the amount you have leftover on a loan if you are calculating the interest rate of the remaining balance. This number is completely up to you, and it provides you with a way to find out how much you can afford to borrow based on the monthly payments you can afford as well. To find out the total amount of cash advance that you will have paid in total by the time the loan is paid off, you multiply the monthly payments by the total months of the loan (loan term years x 12).
Posted on Sep 12, 2011
I have a P1 code and a red flashing symbol and the air conditioner is only blowing air not cold?
Hi Sharyn. I do believe that your air filter maybe dirty. Or possibly the exhaust is clogged.
Hollar back if that doesn't do it for ya.
Jan 17, 2015 | Watches
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
How to enter code for freelander 1998 Radio R770
Philips / R770 Rover Code Entry
Switch on the radio, the display will show 'C'
Press [P1] followed by the tuning button to rotate the first digit
Press [P1] followed by the tuning button to rotate the second digit
Press [P1] followed by the tuning button to rotate the third digit
Press [P1] followed by the tuning button to rotate the fourth digit
Finally if the correct code is shown on screen press the [P1] button to save the code.
Jan 10, 2010 | Car Audio & Video
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
When I press the power button the pc runs the fans
You're power supply is on the way of going out if it's not already. Get a new one as soon as possible. If it started after a while it sounds like it was overheated and starting it again may have been the final straw.
Nov 10, 2009 | Thermaltake Toughpower 750-Watt Power...
Dishwasher problem
Hi Sharon , Im not finding your model number dwf415. See if you have high temp wash and heated dry buttons on your dishwasher. If you do, press high temp wash, heated dry, high temp wash, heated dry in that order. This will run the service mode and reset the board. If you don't have those buttons post the cycles you have or the full model number. Catriver
Aug 09, 2008 | Dishwashers
Everstar MPM1-10CR-BB6
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
Jun 17, 2008 | Danby DPAC8020 Air Conditioner
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
Top Dishwashers Experts
