Tecsun BCL-2000 (Grundig s350) selector knob getting worse
I have a Tecsun BCL-2000 which has worked reasonably well for the five years I have had it. But now, the dial that switches bands does not get the band right away. I have to wiggle it around before it gets into the correct band. This problem is getting progressively worse.
Is this a part that can be easily fixed or replaced? I am in Thailand.
informatica
  • 1114 Answers
SOURCE: Radio antennae replacement
You can find one on the following site: http://www.etoncorp.com/Parts_and_Accesories
Posted on Aug 01, 2007
SOURCE: AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Posted on Oct 22, 2007
  • 71 Answers
SOURCE: DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Posted on Dec 10, 2007
SOURCE: Color bands at the top of the screen - Sony KDF-50E2000
I have the same TV with the same problems. Sony has issued a recall for these tvs. Contact sony and will fix it for free or give you a discount on another tv.
Posted on Jan 21, 2009
memturbo
  • 226 Answers
SOURCE: I need only the antenna for a Grundig S350 Radio.
here
Posted on Mar 27, 2009
Dewalt service center
The Grundig S350 (DL) runs on one of three power sources: electrical outlet, DD batteries, and AA batteries. There is a switch in the battery compartment that permits to change battery type. I do not know how different the S350 and the S350 DL are, but you should try to find out if it works with any of the two battery types before having it serviced. Clean all contacts of any acid corrosion. Check the manual to see if you have to specify the battery type in the setup too.
Feb 05, 2014 | Grundig Audio Players & Recorders
Grundig r2001 radio error 3 cant sort it after flat batt
The picture shows an S350 -- if your model looks like that but with a different designation this fix may still work:
Look above the gain knob (bottom right) and then above the Tuning fast -- slow lettering. You should see a reset hole. Use a paper clip to reset the radio.
Ringbearers
Apr 04, 2011 | Grundig S350 AM/FM/SW Radio
S350 won't stop scanning on AM/MW mode. Tech support said reset with paper clip but that won't stop it either. Any thoughts? John G. Warren john.g.warren@jci.com
Strange. How can it, since that Radio does not have an Automatic Tuning System. To tune in to any frequency you have to turn one of two knobs. Are you sure about the Model Number?
Oct 06, 2010 | Grundig S350 AM/FM/SW Radio
Dropped my portable grundig s350. Stopped working
Anything could happen in a fall, no telling what needs attention, could be a bad battery connection a cracked circuit board. If it is under warranty send it in if not a good technician is needed.
Jan 24, 2010 | Grundig S350 AM/FM/SW Radio
No sound after dropping S350.
Probably one of two things:
The dropped caused the speaker leads from the PCB to Speaker to disengage (check the earphone jack, too... 'cause it is in the circuit)
or
The bounce cause the Audio amplifier IC to become desoldered from the PCB.
Mar 06, 2009 | Grundig S350 AM/FM/SW Radio
I replaced the batteries in my S350 and it started smoking.
There are any number of reasons for this to occur, but I would call Eton customer service in California. They're very helpfull and the number is located on the manual that came with the radio. If you no longer have that, just go to their web site.
Unfortunately, the limit on the warranty has run out, so their is probably nothing that can be done outside of buying a new one. ACT Electronics can fix Grundig radios, but the price will probably exceed the cost of this model.
Dec 27, 2008 | Grundig S350 AM/FM/SW Radio
Intermittent volume level
Radio Shack does provide a volume control cleaner that you could gently spray to clean the contacts, but you may simply have a defective knob. (The first S350DL I bought had a defective volume control.) Don't hesitate to call Eton Customer Service either.
I hate to say this, but I've become a little wary of buying radios at Radio Shack. I have a suspicion that occasionaly radios that are returned get "recycled" back into stock rather than sent back to the manufacturer. I had to return 2 radios directly to Eton / Grundig after getting back to back defectives at RS.
Oct 21, 2008 | Grundig S350 AM/FM/SW Radio
Failure of radio to turn on
It sounds like a component on the circuit board is heating up. Open the radio up and check if anything is overheating, if so replace the defective part.
Jun 20, 2007 | Grundig S350 AM/FM/SW Radio
Grundig S350 digital display
The radio is analog with a digital display. Mine displays off all the time, you can try turning the other switches on it just slightly. Just move them a tiny amount. This seems to correct my problems. Heat is also another factor with these things, they drift all over the place.
Dec 09, 2006 | Grundig S350 AM/FM/SW Radio
211 people viewed this question
 Grubhead
Grubhead
