Question about Air Tools & Compressors
I have a ingersoll rand air compressor IRN-100. The DRIVE FAULT 29 appeared.
I checked the IGBT, all the connector around the IGBT, the power supply and many things else. Can you please help me with that. Thank you
  • 1388 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
Posted on Jan 10, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 169 Answers
SOURCE: The compressor starts and stops after a short
More than likely it is a problem with the inlet control, commonly I have found wear in the throttle linkage can cause this or a faulty sump pressure sensor that is out of calibration.
Posted on Mar 07, 2010
SOURCE: 40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Posted on Mar 12, 2010
On my Ingersoll XP375 I have a shot-down cote 29
say try this troubleshooting manual on your issure sna see if you can get it going again. best i csn do for you hope this helps youout.
Nov 10, 2017 | Ingersoll Air Tools & Compressors
My Ingersoll XP375 has a code 29
Here is my info from the manual. Hope it helps...
Engine shut itself down: reason unknown
Explanation: The engine has shut down. The WEDGE did not shut down the engine.
Effect: Code 29 is a SHUTDOWN condition and will shutdown the machine.
Code 29
Action Result Step1:Check the machine fuel system and engine fuel filters. Check
for loose fittings in the fuel piping that could allow air to be
drawn into the fuel system. step 2:Verify the throttle signal from the WEDGE is continuously
supplied to the engine. A quick drop in the throttle signalcould cause the engine to stop step 3:Verify battery + and - connections to the engine controller,
inspect harness connections and measure voltage drop at
engine ECM. step 4:In the case of the l-R (John Deere) engine, check the
connections for the crank sensor which is mounted at the front
of the engine. Loose pin connections in the connector will
cause code 29.
The Link:
Nov 09, 2017 | Computers & Internet
VSD fault 29 problem with ingersoll rand nirvana irn75
IGBT-board is faulty conduct a power module diagnostics
Dec 28, 2014 | Ingersoll Rand Air Tools & Compressors
IGBT-driver board is faulty conduct a power module diagnostics
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
these compressors are costly even the parts to maintain.I would first check if you cooling fan for the vsd drive is working which is located in the electrical panel of the compressor.A failing fan or one that has failed would cause this fault
Mar 22, 2014 | Ingersoll Rand Air Tools & Compressors
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Mar 21, 2014 | Ingersoll Rand Air Tools & Compressors
What is a vsp fault 10 alarm Ingersoll rand
A VSD 10 fault is bus oscillation. Quickly rising and falling voltage. Recommend having power company check incoming voltage for oscillation.Voltage can not vary more than 3 percent or alarm is issued.
Mar 09, 2011 | Ingersoll Air Tools & Compressors
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
73 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
