Give this a try to see if it'll reset...disconect power to it for 30 seconds while no power press power button for 10 seconds then press the start/pause button for 10 seconds. Plug in or turn breaker back on and see if it reset.
I don't have a model number but it sounds like the unit is in the life test mode. I'm assuming that since you have tried to calibrate it, you know how to get into the test mode. PUT THE UNIT INTO TEST MODE, THEN TURN 13 CLICKS TO THE RIGHT SO THAT WASH, RINSE AND CYCLE COMPLETE OR END OF CYCLE IS LIT. PRESS START. ALL LIGHTS SHOULD GO OUT AND NOW YOU ARE OUT OF THE LIFE TEST MODE. THIS IS USED AT THE FACTORY FOR EXTENDED TESTING AT FACTORY WITHOUT HAVE TO RESTART WASHER
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similarthermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
when you reassembled the case you have pinched the clear tube that goes to the water pressure switch aginst the case and back panel, lift up the console remove the case clips and make sure that the pressure hose comes up through the curve part in the case if pinched off the pressure switch will not satisfy
let me know if you need any more help
