Question about Proscan Televison & Video
WHERE CAN I BUY A TV BASE FOR 19INCH TV PROSCAN
5 Suggested Answers
  • 326 Answers
SOURCE: need to remove base from Proscan 32" TV
The stand can be removed by unscrewing six phillips-head screws from the back panel. A plastic insert plate is provided to cover the bottom hole that is left when removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: hi i have a ploblem i bought this proscan lcd
If you are trying to turn it on with the remote and it does not come on then probably the batteries in the remote have gone weak- change them and try.
If you are trying to put it on with the On/Off switch on the TV and it is not coming on then there are 2 possibilities- the power cord could have come loose, or you have a fuse blown in the TV. Locate the plug and check if has come off. If the fuse is inside the TV then there is very little you can do (unless you know how to open these things and put them back).
Try the above, it seems to be a minor problem.
Posted on Aug 28, 2009
Slinteriors
  • 8617 Answers
SOURCE: need to buy a power supply 12V 5A for a Proscan LCD TV Model 19LA20Q
www.tvrepairworld.com will most likely have the board you need.
Posted on Apr 22, 2012
jerardi
  • 14162 Answers
SOURCE: I need to buy a new or used base for my 42 in proscan lcd tv.
Wal-Mart, Best Buy and Sam's Club, Kmart, Target, Radio Shack.
Posted on Feb 25, 2015
Remove the base on proscan tv
There are many different models, I don't know which one you have.
You can search for the correct user manual with the correct model number. Most are very similar. Here is a link to a user manual with instruction on how to install a base. Removing the screws shown should remove the base.
Proscan 32LB45Q User Manual Tv Stand Installation
http://www.manualslib.com/manual/311999/Proscan-32lb45q.html?page=9#manual
Aug 15, 2014 | Televison & Video
Other than going to Thompson who is RCA/GE/Proscan you can Google the model number with base to see what is available.
Dec 10, 2012 | Proscan 42LA45H 42 in. LCD TV
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Jul 14, 2011 | Proscan 32LB30QD 32 in. LCD TV
Need a new base
Tries websites like Amazon.com,Ebay.com to buy a used or a new tv base stands.
May 22, 2011 | Proscan 47LB45H 47 in. LCD TV
How do you remove the stand on a samsung 19inch lcd tv..
There are 4-6 screws that must be removed. look on the rear of the TV for screws at the base of fairly deep holes. They require a #2 phillips head screw driver. Remove all of the screws and then get a friend to hold the base whild you pull the tv straight up about 6-7 inches. Joe
Mar 29, 2010 | Samsung 933HD 19 in. LCD TV
Need to remove base from Proscan 32" TV
hope it helps
Mar 26, 2009 | Proscan 32LA30Q Television
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
