Question about Proscan Televison & Video
Looking for tv base for 19inch proscan model#PLEDV1948A S/N a1209086090006198 AND HOW MUCH DO IT COST
5 Suggested Answers
SOURCE: how to remove base support from PROSCAN LCD TV( model 26LB30Q)
Remove the srews under AUDIO-L/R and HDMI-1.
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: hi i have a ploblem i bought this proscan lcd
If you are trying to turn it on with the remote and it does not come on then probably the batteries in the remote have gone weak- change them and try.
If you are trying to put it on with the On/Off switch on the TV and it is not coming on then there are 2 possibilities- the power cord could have come loose, or you have a fuse blown in the TV. Locate the plug and check if has come off. If the fuse is inside the TV then there is very little you can do (unless you know how to open these things and put them back).
Try the above, it seems to be a minor problem.
Posted on Aug 28, 2009
budmrtn
  • 11361 Answers
SOURCE: What is the cost of a high voltage
You need to look at part number on the board assembly first, not all 19LA20Q use the same manufacturer of the inverter, once you have have the P/N, then you can go on EBAY or www.lcdparts.net. I would estimate from $30~50.
Posted on Nov 01, 2009
dduncan774
  • 760 Answers
SOURCE: I have a Proscan 32
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Posted on Jul 14, 2011
Remove the base on proscan tv
There are many different models, I don't know which one you have.
You can search for the correct user manual with the correct model number. Most are very similar. Here is a link to a user manual with instruction on how to install a base. Removing the screws shown should remove the base.
Proscan 32LB45Q User Manual Tv Stand Installation
http://www.manualslib.com/manual/311999/Proscan-32lb45q.html?page=9#manual
Aug 15, 2014 | Televison & Video
I need to buy a new or used base for my 42 in proscan lcd tv.
Other than going to Thompson who is RCA/GE/Proscan you can Google the model number with base to see what is available.
Dec 10, 2012 | Proscan 42LA45H 42 in. LCD TV
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
Jul 14, 2011 | Proscan 32LB30QD 32 in. LCD TV
How do you remove the stand on a samsung 19inch lcd tv..
There are 4-6 screws that must be removed. look on the rear of the TV for screws at the base of fairly deep holes. They require a #2 phillips head screw driver. Remove all of the screws and then get a friend to hold the base whild you pull the tv straight up about 6-7 inches. Joe
Mar 29, 2010 | Samsung 933HD 19 in. LCD TV
What is the cost of a high voltage board for a Proscan TV Model No. 19LA20QW
Nov 01, 2009 | Proscan 19LA20Q LCD TV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
