Question about Lands Phones
I had my phone for less then a year.I had 254 days left.the next day it said 23 days.Why?
4 Suggested Answers
nliwilson
  • 114 Answers
SOURCE: Resurrection
Sadly the chances are not high. the bootload screen tells you that Palm OS has not even loaded, assuming you have tried a soft reset this would suggest that the devices memory is either inaccessible or damaged. Anything you try is going to be a slim chance but what do you have to lose by trying? If you reset your palm with it plugged in to your PC via a USB cable there's a small chance you may force it to act as a USB memory reader, as such it will show up in My Computer as a drive or if you have a memory card in the phone it will show up as 2 drives. I cannot stress enough that this is a slim chance though. If you are familiar with telnet and serial data communications it is stall possible to access a palm this way and possibly find your data, however this is a very involved procedure that will require a steep learning curve if you don't know what I'm talking about and still represents a very slim chance.
Posted on Aug 13, 2007
  • 320 Answers
SOURCE: Doesn't work, just beeps
The machine will not run if the covers for the coffee grinder, the filter basket and the machine itself) are not properly closed. It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button. Hopefully it should work.. Leyt me know..
Thank you.......
Posted on Oct 02, 2008
bugoy31
  • 1238 Answers
SOURCE: Hitachi L26D103. Less than 2
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  1. Remove the back cover of your TV.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
Posted on May 06, 2011
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
How do I reset the Date and Day of the Week on the display of my Avaya phone?
The day program was taken out on newer models of Partner systems where it uses the date to figure out the day of the week.
Changing the date on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#101"
the display should say system date and the current data in mm,dd,yy format
enter the new date month, day then year
press feature "00" to logout
If you have an older model Partner system,you'll also have to enter in the day of the week in programming
Press the feature key and "00"
enter in "#102"
the display should say system day and the current programmed info
enter the new day, 1= sun, 2= mon, etc.
Jun 25, 2010 | Avaya 700340193 Corded Phone
Battery needs jump start if car is not driven for 3 days.
u either have a shorted cell in the battery or the system has a current draw like a glove box light being left on, try disconnecting the battery the next time you leave it, if it starts ok then u have a current draw and need to find the source of that draw.
Mar 16, 2009 | 1994 Jaguar XJ6
Hi i need to know that how to programmed the timer test
you should have your company program this. howerver her is the infor if you know hoe to get into programing.
Option 16: Auto Phone Test (Default = off)
Determines whether the panel automatically performs a periodic
phone test (on) or not (off).
The test interval can be from 001 - 254 days. Entries must be
3 digits. The time of day the panel performs the test is determined
by Option 72: Supervisory Time, which must be
turned on for this feature to work.
Note
For UL 1635 listed systems, Auto Phone Test must be set to 001
days.
 To set Auto Phone Test, press:
1. Add
2. Option #
3. 16
4. Use the numbered keys to enter the number of
days 001 - 254 (all entries must be 3 digits).
5. DONE
 To turn off Auto Phone Test, press:
1. Delete
2. Option #
3. 16
4. DONE
mj
Dec 05, 2008 | GE Security Simon 3 Wireless Home Security...
Setting the time..
Normal 0 this is how ive changed the time before, note that you dont see the number you type in.
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Oct 27, 2008 | NorStar M7310 Corded Phone
Setting date & time on M7310
Normal 0 TIME CHANGE PROCEDURE: DONE FROM THE MAINPHONE
The display will shoe hours.
Press CHANGE.
let me know how you get on
Sep 15, 2008 | NorStar M7310 Corded Phone
Reset clockdue to power outage.
hi, this worked for me
Press CHANGE.
this has to be done fro the main phone system
hope it helps
Jul 09, 2008 | NorStar M7310 Corded Phone
Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press CHANGE.
Apr 16, 2008 | NorStar M7310 Corded Phone
Wrong Day
Unplug the phone until it gets to that day?
Jan 04, 2008 | Motorola Mobility C51 SD7561 Phone
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
