Images looks like ghosts. background is black. please help.
4 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Posted on Sep 08, 2007
  • 158 Answers
SOURCE: Colour printing gives ghost image
Are you using genuine Brother color cartridges? If you are, then try different paper (20 pound laser printer paper or plain paper copier paper rather than inkjet paper,) Also, do not use recycled paper. If that does not work, you may need a new imaging (OPC belt) unit, or a new fuser assembly. Check your owners manual about when to replace the imaging unit or fuser. It is usually after 60, 000 prints have been run.
Posted on Jun 09, 2008
mohanchennai
  • 490 Answers
SOURCE: black background when scanning in greyscale
There is an option to set the brightness/contrast in the first page of Capturperfect. Select automatic if you cannot manually set it.
S. Mohan
Posted on Apr 04, 2012
Acer aspire l320
In a bright light do you see a "ghost image" on the screen? Have you tried a External Monitor? This may help: http://www.youtube.com/watch?v=2Yi6GNFcP3w
May 24, 2013 | HP Mini Computers & Internet
Day time all is good . after 5:00 or so it is very slow **** mostly no signal at all.
Your internet? if its your internet than you need to talk to your provider. If it is your laptop then you must have a program taht auto-starts at 6. I suggest you look through all your processors and make sure you aren't running a ghost image program which slows down your computer.
Hope this helps ^^. Please dont forget to rate, Thanks
Feb 28, 2010 | Computers & Internet
Printed page not clean, faded characters in background of page. Any suggestions? I cleaned the pickup roller.
Have you tried another toner cartridge? And when you say it has faded characters in the background? Does it look like it's reprinting the image kind of? If so, you will need the fuser unit replaced. The fuser is responsible for melting the toner to the paper, when it goes bad it can cause "ghosting" meaning it reprints previous images. A technician would be needed at this point, the part number for the fuser is RM1-1289.
Please let me know if there is anything else you need.
Aug 03, 2009 | HP LaserJet 1320 Printer
Background ghost like images
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Feb 27, 2009 | Televison & Video
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Double image
have you done convergence? and is there a auto focus?
Jan 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Plasma Display
call 905 565 6595 Ontario, to get fixed ur tvs.
Nov 06, 2007 | Televison & Video
Picture shifted and ghost image
Sep 08, 2007 | Toshiba 34HF81 34" TV
Sony KP-43T70 green ghost problem
The cause of the problem can be that the CRT-s are getting weak. Life span of CRT is around 30000 hours of working time. Please calculate. If you need more info please advice.
Apr 03, 2007 | Sony KP-43T70 43" Rear Projection...
k24674
jasbo
jasbo
