Question about The Computers & Internet
I played around with the settings to educate myself so i was suprised to see the background color change. i am unable to fix it.
2 Suggested Answers
SOURCE: changing black background color
download the themes from net and then install it......................
Posted on Feb 11, 2008
Want to add background color to my yahoo homepage as easy as possible
With XP, you right-click, click "Use as Background".
With Windows 7, right-click the page in an area where the preferred background is shown. Click "View page Info", click the "Media" button, select the Background image and it should show in the lower pane. If not, cursor up or down till the preferred image is shown., click "Save As..", change to the preferred folder and save the file with a preferred title. Withing Display Properties, locate and change the Background image to the saved file.
Even finding the proper area to change the background image depends on your Windows version.
Nov 17, 2013 | Computers & Internet
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Making the background of my document a color
You can't really change a setting to do that. You can change the document to have colored background, or the easiest way, buy colored paper. Why waste all that ink.
Jan 15, 2013 | Canon PIXMA iP1600 Printer
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
What is the basic code for html code for background
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
Mar 16, 2011 | EliteGroup Computers & Internet
How to change the color of the background?
This is pulled from the tutorial PDF:
================================ DESIGNING YOUR MENU Now that your content is added, you can customize the look and feel of your menu. You can change the background, title, and chapter button layout and text. Before changing your text, it's recommended that you set your background first. Often, the color of your text will be dependent on the background color. A good amount of contrast between the colors is necessary to ensure that the text stands out clearly ================================
The option to change the background is in the Themes tab.
Mar 02, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Tekan tournament
Alternate Mokujin sounds
To hear different hit sounds for Mokujin, hold DOWN on the D-Pad or joystick before a match in which you are controlling him. Mokujin will now sound like a block of wood when damaged.
Arcade History Dip Switches
While at the Press Start screen for any of the Arcade History games, hold the select button and you will be given a list of dip switches. You can use these for such things as changing number of rounds or unlocking hidden characters, such as Baek in Tekken 2.
Choose Victory Animation
After winning a round and you see the replay showing, pressing each button( [X], [O], etc...) will result in a different victory animation. This also works when the opponent wins.
Play in 'Devil' mode in 'Devil Within' mini-game
This allows the player to play as Jin in permernent Devil mode without having his life bar drained out. The devil bar will be considered as his laser bar. The downside of this code is that it kills of you opponents faster thus unable to reach a higher combo rate.
Note: You must clear Devil Within under Medium difficulty. Then start a new Devil Within or Stage Select.
Nov 11, 2009 | Video Game Consoles & Games
Background color
1. select the brush tool. the background and foreground colour.
Apr 06, 2008 | Adobe PageMaker 7.0 Classroom in a Book...
Blue shadow
If the blue shadow is convergence you should have an option for convergence adjustment via the remote control to converge the blue onto the green. If it doesnt move then its probaly a IC problem. What make and model set do you have?
Jan 02, 2008 | Televison & Video
tune down the settings in game. example: changing screen resoloution from 1200x1000 to 800x600, also decreasing the quality may help. another thing you can try is exiting ALL applications that are running while the game is running that are not needed, such as any downloading clients or anything that may be using up some of your computers processing speed.
Sep 12, 2007 | Video Game Consoles & Games
Computers & Internet Logo
63 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
