Question about LG Washing Machines
My LG front loading washing machine leaks from the bottom when in use. I have check the filter and it is clear. The tube beside it seems to be clogged and when I unscrew it no water out
  • LG Master
  • 2,305 Answers
Take top off, take control panel off, take wire clamp off front of door boot, take front panel off, check all hoses for holes/leaks. or have how to videos.
Posted on May 10, 2017
Hello, My L G washing machine has an error code OE... what does that mean?
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 20, 2014 | LG WM-2277HW Front Load Washer
LG WM2277H front load washer isn't draining.
there is a clog somewhere in the drain for sure see the link below
if you think it has been cleared unplugg for 10 minutes and see what happens LG Front Load Washing Machine Error Code OE How To Clear
steer clear of LG as a repairman for a living they have weird problems like this all the time
over computerized with lo grade parts inside from my experiences
Feb 03, 2018 | LG WM2277H Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 26, 2011 | LG WM2042 Front Load Washer
Washer leaking from bottom when first turned on and tub filling, already checked inlet valves/tubes in back-no problems. Already drained filter and filter tube, did not resolve
Did you check your bellows for tears.That is the rubber that attaches tub to front of washer. the part that the door closes on. check in and around for tears in it ...Good luck if i helped you please vote ..thank you
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Leaking water from underneath;I check the filter and that was not clogged. Happens on both cold and hot water washes.
there is a hose behind the cover on the bottom left side that is clogged or maybe has cut in it you may be able to just cut bad part out and still use it
Mar 15, 2010 | LG WM-2277HW Front Load Washer
OE Error suggestiong drain filter is clogged - where is the drain filter?
the drain filter is at the bottom also check the syphon tube to the left of the filter
Oct 31, 2009 | LG WM-2277HW Front Load Washer
De error code
"dE" means that the door hasn't been closed properly. Check the inner seals of the washing machine particuarly at the bottom where water can get clogged. Also check the rubber seal around the front door to see if it has popped out or out of alignment. Also, "DE" in full letters can mean that the drain needs to be cleaned. Switch off the washing machine, pull out the flap on the bottom LH front of the machine, find the water tube and drain the water out of the LG. Then unlock and inspect the actual plastic tray/grid when twisted to unlock and pull out. There should also be a "drain" function on the main dial as a general maintenance option. Make sure you do this to keep your machine going.
Dont forget to rate this please if this solution works. Many thanks.
Mar 28, 2009 | LG WM1812C Front Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Washing machine trouble
Very important that the thin tube is clog free, disconnect from top to blow into it, clear if any block, refit. This is connected to the pressure switch, controls water level.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Important: height of drain hose is abt 3 feet from ground level.
Rate me pl.....if helped.
Jan 03, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
