Question about Polly Pocket Toys
1993 Polly pocket school house light bulb repair
How do I change the light bulb in the 1993 Polly pocket school house?
3 Suggested Answers
  • 59 Answers
SOURCE: how to change bulb in back window stop light of 1993 mustang
try pressing the sides of the brake light body and pulling the parts apart. Or use a simple will see how.
Posted on Apr 15, 2009
SOURCE: I need instructions on how to assemble the Polly P...
If you find them, could you email to We just purchased the set at a garage sale and I don't have instructions either. Printed the photo and I am going to try and go from that :)
Posted on Aug 07, 2010
Does anyone know how to remove this 2009 Lexus ES 350 third brake light housing so I can change the bulb for my mom?
These Videos Can Help.
Although these videos are not specific for your Lexus, but the procedures are similar from car to car, even if different years, makes and models.
How to Remove 3rd Brake Light Third Brake Light Bulb Change
Lexus ES300 1993 1996 1993 Lexus ES300 3 0L...
Have a nice day.
Apr 02, 2016 | Vehicle Parts & Accessories
Changing headlight bulb.
Some car it is hard I did G6 took me one hour.You can get bulb or whole light out.
Apr 25, 2013 | 1993 Chrysler Lebaron
My 1993 BMW 325is Right Rear Brake Lite does not work. The Bulb has been changed with no success. This has that Rear Tail light assembly where the bulb is placed into a holder and then that is twisted into...
Remove the the bulb and check the holder for corrosion and take a small screw driver and bend the leads closer together. Also check the leads on the outside part, that they are not flattened out, again bend them up.. And check the plug that goes to the housing for corrosion and if neessary bend the clips a little closer together.
May 03, 2011 | 1993 BMW 3 Series
Prelude bliker not working left side (driver side
First try that new bulb in the other working side just to double check it. If it blinks then great. Second take a pocket knife or a toothbrush size wire brush and scrape the inside of the bulb housing so the bulb can get a better ground, Clean the conntact point that the end of the bulb sits on in the bottom of the housing too. Let me know if this does the trick, I can use all the thumbs up I can get. Raz
Apr 19, 2010 | 1993 Honda Prelude
Need Instructions for Polly Pocket Party Game (board game)
I too am looking for the exact same thing. Did you or does anyone have instructions for this game? Please???
Oct 04, 2009 | 2005 Toyota Corolla
I tried to reset the polly pocket electronic secret safe to use a new code and it won't work?What do I do?
The default code is "Polly"... Use this after resetting with the reset button or remove batteries...
Jun 17, 2009 | Kiddieland Toys
How to change bulb in back window stop light of 1993 mustang
Mar 27, 2009 | 1993 Ford Mustang
Belt is coming off botttom polly when i put a new alter. and bel
You need to Replace that Belt Tensioner. This will fix your Belt Problem. Please Rate My Response! Thanks!
Jan 31, 2009 | 1993 Chrysler Lebaron
Drivers Side brake light bulb is burned out.
Pull the panel back on the INSIDE of the car's hatchback or trunk. The bulbs twist in from the back.
Dec 03, 2008 | 1993 Ford Mustang
How do you change the fog light bulb on 1993 zx?
Take out the small screws that hold your turn signal/marker lights on. This will allow you to reach in and undo the three (if I remember right) 10mm nuts on the back of the fog housings that hold them in the bumper. Once they're removed, press on the back of the fog housing and the foglight assembly will pop out of the bumper. Then you can replace the bulbs.
What I did on my Z is something you might consider - while I had them out, I took them apart (just a couple screws and bolts, very easy). Open it up so that you have access to the glare guard - the cup that sits in front of the bulb. This blocks forward projection of the light, and instead bounces it onto the reflector to be spread very wide (but not far forward) in a fog beam pattern. I used pliers to physically break the guard off the housing, so that instead of a wide, shallow fog pattern, I had a forward-projecting driving beam. I also swapped the 35w OEM bulbs for 55w higher-output superwhite bulbs (this increase in power consumption is not enough to cause any risk to the wiring or fusing, by the way - it worked for years for me). Then put them back together and reinstall them - you'll find a drastically improved light pattern for night driving, and they're still low enough to the road to cut under most fog. Especially since I always felt that the Z headlights were pretty pathetic for output (at least until I installed HID lighting), this was a great mod to make to the car.
Sep 04, 2008 | 1993 Nissan 300ZX
Toys Logo
44 people viewed this question
Top Polly Pocket Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Polly Pocket Toy Expert? Answer questions, earn points and help others
