Question about Air Tools & Compressors
IR 75I COMRESSOR AIREND DISCHARGE TEMPERATURE HIGH WHY
    Novelist:
  • 205 Answers
This problem could be due to several items. Low oil level, Bad temp.probe. Cooler stopped up or dirty and not allowing enough air flow thru it or maybe a thermostat. Also temp. in compressor area can be causing problem also.
Posted on May 15, 2017
2 Suggested Answers
  • 33 Answers
SOURCE: 7.5 tas high airend temperature
1. Check your oil level, top up, or totally replace it
2. Check your cooler (Radiator looking thing) blow it out with a blow gun
3. Check your thermo valve (may need replacing)
4. Is the room that your compressor is in very warm, ambient air is a big factor in the running of your compressor
5. Do you have all the panels fitted to the machine? These are needed to aid airflow past your air-end
These are the main causes of high air end temperature. It may just need a good service
Hope this helps
Posted on Aug 30, 2012
Ingersoll rand compressor model no 75i high airend discharge temperature trip why
Wash the cooler first. Then replace thermostat if washing cooler d't take care of the problem.oesn
May 08, 2017 | Ingersoll Rand Air Tools & Compressors
What cuases high a/e discharge fault on ingersol rand air compressor
Dirty coolers are always associated with high discharge temps,always make sure your coolers are clean
compressor oil filters being clogged can also raise your temp n cause the unit to over heat,and on the much bigger machines if the compressor oil pump fails then you will have severe over heating as the oil flow to the cooler is assisted by the pump!!things like regulating pressure should always be adjusted to the machines specs so it doesn't over pressurize n put load on your airend while the engine is at idle.
Jun 24, 2014 | Ingersoll Rand Stationary Air Cooled...
Fire in coalescer filter
high airend discharge temp oil level to low or no cooling taking place
Mar 03, 2014 | Ingersoll Rand Rotary Screw Compressor ...
Hope this helps
Aug 29, 2012 | Ingersoll Rand Rotary Screw Compressor ...
Ingersoll rand air compressor model SSR-UP5-30-14 frequent trip on high airend temperature ....what is the solution ? and another unit ( same model ) always trip on " starter fault ". Untill...
check if approach and discharge pipes to oil cooler are similar temperature as there is a thermo bypass valve that controls the flow through the cooler if cooler is quite cool but still very hot inside this could be stuck in closed position causing restricted flow through the cooler
Sep 20, 2011 | Ingersoll Air Tools & Compressors
I have IR 2000 air compressor and it ejects large amounts of coolant out of the air inlet. It seems like this occurs more so when it is hot. This has only happened with IR air compressors.
I need to know if this is a rotary screw compressor or a piston compressor. Ir makes a 2000 in both. If this is a older ssr2000 rotary I would first look at the minimum pressure check valve. It is located on top of the seperator tank. The top cap will screw off. In it is a large spring ,a piston ,a small spring and a disc with teflon seat. check the teflon seat. Make sure all are clean and slide in the bore of the valve freely. I use sil glide lubricate from napa to lubricate all parts. if the o-ring is damaged it will need replacing. I usually get a kit from IR if any parts need replacing. Reassemble. the next place to look is on the 4 " line from the bottom of the airend to the seperator tank. In this line close to the airend between a flange is the check valve. If you remove it look closely at the orientation of this valve. If not reinstalled properly it will not close and let large amounts of oil back into the airend. check for wear, sticking etc. It should be very free and close easily.
Jul 12, 2011 | Ingersoll Air Tools & Compressors
I have a 7-41 I.R. compressor. Recently serviced with 1200 hrs done. It now only runs for about 20 mins before shutting down. After 15 mins she starts again. I have tried bypassing water temp sender and...
make sure the cooler(s) are clean. Next check the airend discharge temperature switch commonly called a HAT (High Air Temp) switch. These switches will reset as the compressor cools down. I would be able to access the switch quickly. Run unit until shutdown remove wires and see if switch is open. if open you found your problem
Jun 01, 2011 | Ingersoll Air Tools & Compressors
I have a sullair ls - 120 we have been having problems with it getting hot and shuting off oil levels have been fine we have tryed different oil types we have took apart the unloader valve cleaned it and...
Get yourself a temperature gun and check a couple things:
1) Measure the oil injection temperature to the airend. This is a line going into the bottom side of the airend. 2) Measure the discharge temperature from the airend (this should be the same reading as the temperature gauge/readout on the compressor, but check to be sure)
You should get a temperature rise of about 25-30 degrees F over the airend. If you have more rise, you probably have an oil restriction: try an oil filter change.
If your oil injection temp is more than 160 degrees F or so, check the operation of the thermostatic valve. The thermo valve is a T shaped valve in the oil circuit. The oil line out of the bottom of the sump probably goes to a tee which splits flow to the cooler and the thermo valve. The oil goes through the cooler then to the other side of the thermo valve. The thermo valve should then mix the hot oil from the sump and the cool oil from the cooler to maintain the injection temp in the 150-160 degree range.
If you have cool oil coming from the cooler (should be maybe 140 F or less, and the injection temp is high, the thermo valve is bad. You can get a thermostat kit from your vendor to repair. If you've replaced the cooler, this thermo valve is probably the problem.
Mar 30, 2011 | Air Tools & Compressors
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
Mar 03, 2010 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
61 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
