Question about Coffee Makers & Espresso Machines
Put in 12 cups get 6 cups out - Coffee Makers & Espresso Machines
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Coffee cups are only 4 ounces.
Posted on May 08, 2017
Testimonial: "What I'm saying is:I'm only getting half the liquid out that I'm putting in."
Pasta boat manual
MicrowavePasta Boat InstructionsFor elbow, bowtie, ziti, rotini, and penne
1 serving -1/2cup -water levelat #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving ( serving - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cookseveral minutes longer.
For spaghetti, linguine, angel hair andfettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
Cook Time: servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17)
Nov 30, 2010 | Microwave Ovens
Water does not pass through the Mr. Coffee. Just started out of the blue a few days ago. Heating element definitely works as steam just pours out the back of it but after running for 15 mins or so only...
Most of the time the coffee maker just needs cleaning with some Vingar sulution run though it.Do this about every 6 mouths.what happens specially with hard water it cluggs line up.So go to store buy small or big bottle of Vingar put about 1 cup in and half cup water aloud it to go though cycle's.Then or you may put two cups of vingar and two cups of water depend on how clugg it is.Then after done fill water despenser up to run Full pot like 12 cups,but donot over fill.that cleans it from the Vingar taste.You may want to do this twice.Hope this help,thanks for your question it was a good one.
Aug 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
I don't know how to make coffee.
The best way, if using ground coffee, 1 teaspoon per cup. Depends how big your coffee pot holds of water. So if you're planning to make coffee for 12 cups, just put in 12 teaspoons. Best Part is you can ground your own fresh ground coffee, or ground them at your Favorite Store, like Hazelnut etc.
You can buy the pouches. They make them for 4 cups 6 cups 8 cups, etc. (Like the ones they give you when you stay at the hotel). Fill the proper amount of water, for cups you're making.
My favorite are the single cups. Folgers makes them in regular and decaf. Look like tea bags, and they for 1 Medium Cup of Coffee. After you are done, just throw away.
Good Luck :0)
Nov 11, 2009 | Krups Coffee Makers & Espresso Machines
Not getting all the water
Faulty check valve inside the tubing at the bottom of the unit. This is the tubing conveying water from the outlet of the tank into the heater coil prior to going into the coffe basket.
I have the same problem but cannot find replacement check valve.
Feb 16, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
its most likely evaperating cheaper models are known for this!
Dec 09, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Not Brewing all the way
Exact problem more steam less coffee.
What should I do?
Oct 28, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
