Question about Johnson Boating
My outboard motor locks up, then I turn it backward by hand and it runs until it locks up again. can't find what is wrong with it
Johnson 50 hp outboard motor
  • Johnson Master
  • 3,498 Answers
OUCH... ok.. do not try to start it again.. you can and will cause more damage! Is it in gear when you are turning it backwards or trying to make it run? (need to eliminate drive line issues)
How long with it run after you turn it backwards? ..will it actually run or just turn over? (turning an outboard backwards will damage the water pump impeller!!)..its something you need in perfect working order!
Remove the spark plugs.. see if there is anything on them except a little carbon....We are checking for damage to the piston/rings area. If there is anything on them but a little carbon, you have found the problem area...
If they plugs are clean, (and NOT new).. then you need to check further..You will need a GOOD mechanic to help you.. I would pull the flywheel to make sure you don't have any broken magnets/stator damage.
If the issue is NOT in the lower unit...then its in the power head. Take it to a professional mechanic.
Repost/reply with more info on what you have done.
Posted on Jun 06, 2017
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
  • 23 Answers
SOURCE: I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Posted on Jul 07, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
Editor925
  • 285 Answers
SOURCE: 40 Hp Johnson outboard motors stalls out after a
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Posted on Sep 17, 2009
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
115 hp johnson great difficulty to cold start,sometimes it even run the baterry flat but once it started there is no problem in starting again what could the reason for this be or do i just start the...
Hello vcd9,
When You Turn The Key On ,Press It In To Activate The Choke Solenoid And Then Crank At The Same Time,This Should Solve Your Problem, If All Is Fine With The Engine.
Cheers
Gordon
Feb 11, 2013 | Light Outboard Motor Boat Bass Fishing...
What is the gas mixture for a 9R-70C?
What a neat little fisher motor. All needle bearing motor so you can run it on 50/1 --would use synthetic for the best operation. Take care of that starter spool- slowly engage the plastic gear to the flywheel before you pull the starter for the start.
Aug 06, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Jul 07, 2009 | Boating
Jun 30, 2009 | Sport & Outdoor - Others
Jun 25, 2009 | Boating
Boating Logo
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
