Question about Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit
Compressor blows off, does not maintain pressure
My Porter cable 135 compressor goes to about 140 psi and then blows off. Is there a way to set it so that it does not blow off and maintains pressure?
  • 285 Answers
Hi there. This is normal. The pressure is set to stop at around 120-140 PSI as a safety measure. It probably kicks in again around 80 PSI so as to remain pressurized between 80 and 140 PSI. Since most air tools operate in this range, it is ok for the compressor to maintain pressure in that range. You do not want to adjust the maximum pressure safety release valve as it could be extremely dangerous as certain components in the compressor may only be rated up to 140 PSI or slightly higher before they fail or blow apart.
Posted on Jul 25, 2009
Porter cable 6 gal pressure switch. safety valve blows when tank filling
Depending on the pressure in the tank when the safety valve releases,the problem is likely your pressure switch. If the pressure is at or above 160 psi when it blows, then the problem is the switch.If the pressure is lower, then it is likely a faulty safety valve. There are about 8 versions of this machine. check on dewalt service net for the correct part. you may need to check ebay if the part is nla thru dewalt.
Jul 06, 2014 | Porter Cable C2002 150 Psi 6 Gal...
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
I have a porter cable 6 gal pancake 135 psi compressor. How can I change the cut off and cut on pressure. I've been trying to add air to my car tires and it will not fill the tire all the way up. I was...
where the plug in goes into the pressure switch you can take the cap off and you will see the electrical points and on the inside of the plastic cap it will you show you the two screws to adjust there. one screw will be to raise or lower the min and max pressure equally and the other is to adjust the differential between them. But make sure not to exceed recommended pressure of the compressor or you will blow safety valves, the safety valve will say what pressure it will go off at
Jan 18, 2011 | Garden
Compressor keeps blowing release valve
Compressor pressure switch not working properly. Remove cover over pressure switch. Drain air out of tank. pressure switch contacts should open. If contacts do not open they may be stuck or welded close. Remove power and gently pry contacts apart. If they where welded together this will correct. If this doesn't correct replace pressure switch
Jan 16, 2011 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit Logo
294 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
