Question about Intex Pool & Spa
Intex Pure Spa Jet, E95 code, but the water is not getting warm.
    Top Expert:
  • Intex Master
  • 7,401 Answers
Check heater element
Posted on Sep 13, 2017
  • 1631 Answers
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Posted on Apr 11, 2015
  • 108 Answers
SOURCE: I've got an Intex pure spa hot tub and the air bubbles button isn't working but the LED screen is on??? Any suggestions?
  • Do the other buttons work fine?
  • Did you press REALLY hard and break it
  • Have you tried pressing it REALLY hard when its not broken- Probably a bad idea
  • if you have the know how and the bravery take the face plate off (MAKE SURE THE POWER IS OFF AND THE WHOLE THING IS UNPLUGGED)!!!!!1
  • check the wires going to the back panel of the screen Rusted, corroded? Might be covered under warranty - refer to manual or look-up based on how long you've had unit
Posted on Jun 05, 2015
  • 3 Answers
SOURCE: I keep getting a E96 code on my intex pure spa and
RE: INTEX PureSpa - E96 error code.
This also happened to me, just after having it for 1 year. I followed the scanty instructions in the troubleshooting section to no avail. I called for "technical assistance" twice and got random females with heavy Asian accents and absolutely NO technical know-how.
ME: "I got a E96 error code."
AL (Asian Lady): "When you buy it? If less than year, we send new base."
ME: "It's been longer than that, can I just buy the base then?"
AL: "Yes, $380 and we send it you."
ME: "But I paid $350 for the whole thing new!"
AL: "It's cheaper just buy new one."
ME: "Sure, but can't we troubleshoot this one?"
AL: "We can no more troubleshooting."
No supervisor was available, I was told to hang up and try again for someone else. Persisting, I pried info from one that it was "pump bloken," from the other "bad consore." I believed both were full of it and had no idea what they were talking about.
MY FIX: I disconnected unit from spa. Removed console from base. Turned base upside down to inspect pump and find any ID markings. Found no obvious problem with pump or heating mechanism. Spend few hours time researching cost to buy identical pump. Gave up. Returned to unit, reassembled it, and it worked perfectly!
MORAL TO THE STORY: Intex products are fine, their Tech Support is a joke. I suspect the console had detected air in the pump and that it was stuck in a system error cycle which required a prolonged rest from any power input to refresh. Also, turning the unit over (while inspecting it) may have flushed any remaining water around the onboard pump sensor.
Don't listen to their know-nothing "tech support" when they suggest it is a GFCI problem, (or some of the others here who give this advice without really knowing).
Just keep it fully unplugged for at least a few hours to wipe the system memory!
Since it's a circuit board, it's like a mini-computer. Actually, it's just like a modem that requires resetting. If you unplug it and then replug it too soon, you've solved nothing, the on-board circuitry retains enough voltage to prevent it from resetting. You need to keep it unplugged for an extended period of time.
Hope this helps. Best of luck!
Posted on Aug 12, 2015
  • 48356 Answers
SOURCE: Why are bubbles forming in my intex pure spa jet massage?
the air bubbler is switched on
there is a leak in the suction side of the pump that is sucking in air
Posted on Sep 14, 2015
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
Feb 25, 2016 | Intex Pool & Spa
Sep 14, 2015 | Intex Pool & Spa
Intex pure spa motor isn't circulating water, but the bubbles work. What's wrong? I think I have tried everything. Help!
Probably bad control box for the jet motor/s if the motors are running could be bad pump or a pipe valve issue. Or is there a separate blower?motor that feeds the bubbles (air)
May 25, 2015 | Intex Pool & Spa
Aug 03, 2013 | Pool & Spa
Pool & Spa Logo
142 people viewed this question
Top Intex Pool & Spa Experts
Level 1 Expert
Jay Finke
Jay Finke
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
