Change the paper setting to card in tray 3 on a Infotec copier ISC 2020
  • 313 Answers
Go into the user toools and select paper then scroll down to paper tray 3 and change the size here to the size youj need then scroll down again to the section for paper type and select card thick this should slow the copy speed down as well to feed hte card better.. you could also put in bypass hand feed for better feed. Good Luck A
Posted on Jul 31, 2009
We changed the paper type in tray 3 to high gloss and need to change it back to regular paper but we can't remember how.
Open and close the paper tray 3.The tray information screen will be displayed.Select CHANGE SETTING on the touch screen.You should now be able to change your setting.
Oct 20, 2011 | Xerox WorkCentre 7328 Multifunction laser...
Hi Ricoh 1232 copier and printer. Both copies and prints are produced as if the paper feed was slightly delayed and the print moves over about an inch: effect is you have a large margin on the left side...
Is the paper in the tray landscape-oriented or portrait-oriented? If it's landscape-oriented (short edge is fed first) then you might just need to realign the paper fences. There is a screw holding down the gear in between them -- if you remove that screw you can move the fences so that they're both lined up correctly. (Push them both in all the way or out all the way, then reinsert the gear and screw it back down.)
If the paper is portrait-oriented, it may be an adjustment that will have to be made by a Ricoh service technician. It is a simple adjustment to make, and should only take a minute or two if you can have a tech look at it.
Apr 11, 2011 | Ricoh Aficio 1232C Color Copier
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
Hello sharp sf-2027 error code F3
This is a paper feed tray problem. Check there is no paper behind the cassette. There may be a tray lift problem and this can be caused by paper being trapped behind it. reset the code once fixed by switching the machine off and on.
Good luck
Oct 10, 2010 | Sharp SF 2020 Copier
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
ImageRunner 2020 paper tray open warning - cannot fix
Are you check the sensor flaper for paper presence?
It is located above paper in pick up assy.Whe you remove the drawer you should be able to see the black flaper hanging from above.
Apr 08, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
I dont get prints when I give print command but when I use the
What does it say in the display?..load paper plain letter....load MP feeder? I think the problem is the following. On the menu right arrow over to the paper menu. Hit select...it then gives you sub menus...paper type...paper size. Go to paper size...specify the tray your using...most likely tray one. Hit select and see what size paper its set on. I'm assuming your trying to print on letter size. If it says something else like legal...executive..A4...change it in the menu to letter. If it changes to letter hit select to save the setting. Now if it won't change in the menu pull open the paper tray. The back paper guide is real sensitive on these machines. You have to make sure the geen/blue tab on the back is set exactly into the letter size slot on the tray. That slot will be slightly bigger than the rest of the teeth you see on the bottom of the tray. If you have it set right then there should only be the 2 bottom tabs extending on the outside left side of the tray. Those tell the printer what size paper is in the tray. If theres 3 sticking out...you still don't have it set right for letter size. Okay..the last thing. Something that goes bad on those machines is the tray card. Its where those 2 tabs on the side of the machine I mentioned interface with the printer. They can go bad. You can either replace that card..or trick it. To trick it go back to the paper menu...paper size tray 1. Open the tray...and close it again. The setting on the screen will change to another size...do that again or until it changes to letter size. The leave it alone. You may have to do that everytime you add paper an reinsert the draw unless you replace that card. Hope this helps!
Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
ImageRunner 5570
hello John,
Glad to help. Your copier has 2 seperate sensing devices built into the machine that allows it to automatically recognize the paper size for trays 3 and 4. There is one unit consisting of 2 photo-interruptors that determine the length of of the settings of the paper tray,and a potentiometer that allows the copier to determine the width of the setting of the paper tray. The copier recognizes the paper tray settings automatically as you change them for trays 3 and 4. So there is really nothing required from you other than moving the side guides and the end guide to suite the paper size you wish to insert. The side guides are built into the paper tray and they move in tandem so when you squeeze the blue (I call it a clothes pin since it looks like one) release lever which allows you to change the paper width as you need. To the left of the tray there is a blue square block that is re-positioned as you choose to change paper sizes. This "end fence" should **** against the paper for support and there are markings at the base/bottom if the tray that indicate the proper postion it should be depending on the paper size you need to insert. I believe this pretty much covers it ! :-) Let me know if you need further help and have a great copying experience!!!!! LOL
Jul 31, 2008 | Canon Image Runner 3320I Copier
Sharp sf-2020 4?'s please
pleaz check it in internet by loging www.sharp copiers.com
Sep 07, 2007 | Sharp SF 2020 Copier
81 people viewed this question
k24674
jasbo
jasbo
