Question about Samsung Televison & Video
Samsung TV has Audio but No Image, screen is black no picture at all. Please help. Thanks
SOURCE: hitachi plasma tv 42pd380ta problem
Hi, the ysus board on the left side looking from the rear of the plasma has blownup, this is a very common problem with 42PD380TA, if the unit is under warranty you are lucky otherwise hitachi charge alot of mooney for service kit.
I have seen 7 hitachi plasmas in 3 months all with the same fault.
HITACHI dont accept there is a production Fault
Posted on Jan 23, 2008
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
  • 4234 Answers
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
Posted on Aug 28, 2008
SOURCE: SAMSUNG PS42D4S PLASMA TV HAS
I had the same problem here but I notice that one of the compoent on the power supply board is melted slightly. Suspect that it might be the cause. the compoent have a symbol of transformer and is grey in color...(look like a cap) ...compoent number is L48
Posted on Sep 14, 2008
  • 12 Answers
SOURCE: We have a Samsung Plasma TV we were watching this
Each pixel of a plasma television contains a red, blue and green phosper. These immite a flourescent light individually to produce a nice bright picture. The odds of all of these pixels dying at the same time is so slight, it is likely to never happen before the return of Christ. So your black screen is another problem. There is an ultroviolet light emitting photo that causes these other photons to give off light. My diagnosis without actually inspecting your unit, is that your ultraviolet photon generator needs replacement. These usually last in an excess of ten years so while it may be a costly repair, if you otherwise are happy with your unit, you may want to repair it. Your only other option is to replace it.
Posted on Jun 28, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My samsung ln46c630k1fxza 46 inch t v that has no picture or backlights, i replaced the t-con board, that didnt fix the problem. can you tell me how to fix the problem?
Samsung LED TV Model UN46D6400UFxza has sound but ...
? 2:16
https://www.youtube.com/watch?v=s2hLKzdyDWU
Oct 21, 2013 - Uploaded by Clif Venom
Samsung LED TV Model UN46D6400UFxza has sound but no picture ... LCD & LED TV Repair - No Image ...Missing: ln46c630k1fxza
Samsung LCD TV screen went black (audio on, no picture)
Dec 20, 2015 | Samsung Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Feb 24, 2010 | Samsung 50 in. Plasma TV
My screen from my samsung turns black no image.
Hi my name is Roety,
I can help you with your issue ,
Sounds like a loose green component wire.
check that if thats not the problem, reboot everything
post a model #
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 20, 2009 | Samsung LN-R2050 20 in. LCD Television
Televison & Video Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
