Recorder does not store cable channels
When I scan the cable channels, only 1 or 2 gets stored and I can't add any to memory.
scbu
  • 6 Answers
SOURCE: denpa mp38 digital recorder
The internal memory is the place where the recording itself would have been stored, so unfortunately there is no "extra" memory to cover mistakes such as this...that would be like every PC being shipped with two hard drives in case you deleted something!
However, all may not be lost. The most important thing is DO NOT MAKE ANY FURTHER RECORDINGS OR FORMAT THE UNIT till you have definitively ascertained that the recording is indeed irretrievable.
RECOMMENDED: Trawl the Web for a program called "SoftPerfect File Recovery," download it, and install it (it's a tiny program, about 250kb) - I know you can find it at Snapfiles.com.
Read the help file and follow the instructions...with luck, you should be able to get your recording back.
FYI when you "delete" a file you do not erase it from the storage disk; all that happens is the first letter of the file name changes in the file structure, so the data can no longer be accessed as the device doesn't know where to look. So long as the data hasn't been overwritten by further recording or reformatting, invariably it can be retrieved...this is how the FBI catch all those nasty kiddie porn people out who think they've 'cleaned' their hard drives simply be hitting the delete key.
Hope this helps. If it doesn't then do a google search for 'data recovery software' and try another program. There are many (good) free ones out there, although most are designed to recover deleted photos from media cards. Good luck.
p.s. Would appreciate it if anyone can tell me how to turn on the backlight on my denpa mp-36 unit. I've read the manual and can't find it anywhere. I guess I'm missing that elusive button combination...
Posted on Dec 12, 2007
  • 86 Answers
SOURCE: change/add #'s in Memory
Find your model number and then click this link to download the manual
Manual page
Posted on Jan 20, 2008
SOURCE: Cable & Wireless CWB200H Speed Dial
1. lift the handset.
2.press store
3. pin in number to be phoned.
4. press store
5. press one of quick dial buttons
Posted on Jun 30, 2008
  • 23 Answers
SOURCE: GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Posted on Jul 13, 2008
SOURCE: store a number in memory of Cable and Wireless CWP220
One-touch memory buttons (M1, M2, M3):-
-Lift handset.
-Press STORE button.
-Enter phone number to be stored (up to 16 digits).
-Press STORE button again.
-Press either M1, M2 or M3 button, depending on where you want to store number.
-Replace handset.
Two-touch memory buttons:-
-Lift handset.
-Press a keypad number 0-9, depending on where you want to store number.
-Replace handset.
Posted on May 23, 2009
I am rescanning digital channels after cable change. It tells me no channel is available and defaults to 1-0. I tried hitting enter on the remote nothing help!
Do you see any glimpse of any program during the channel scan. If no, check the cable input connection for any loose contact. If the connection is found OK, the tuner of the TV might be defective.
If you can see glimpses of programs during the channel scan, and no received channels are stored after the scan process has been completed, the main system control memory IC of the TV set is faulty, and should be replaced.
If you wish to get more details, visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 27, 2017 | Televison & Video
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Cant instal record channels tried manuel and auto store no luck
Try unplugging power to the unit for at least 10 minutes or more then plug it back in.. it should try to automatically setup everything. If not manually set the time first then make sure if it has a option to switch from ANT / CABLE that it's set to cable if you have it connected to a cable system. Now try auto scan/store channels.
Nov 17, 2011 | Panasonic PV-V4522 VHS VCR
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
Can'y find where to put in channel
First check that when channels were stored that whatever channel you are trying to record is actually stored on the machine. If all other channels are there and the one you want is not I would re scan and re store
Feb 12, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I hooked my tv up to cable, but cannot get cable channels to work... you can get them by putting numbers in remote, but will not show up when you scan up/down button on remote. Don't haveoriginal remote,...
Is there a Menu button on the remote that activates the Menu function on the TV? If there is, launch the Menu and look for an option titled Channel Memory, or Channel Scan, Add to Memory, etc. This functon will scan the channels and add active channels to memory.
Jul 05, 2009 | Zenith Televison & Video
HOW DO YOU SET UP MORE THAN ONE FAVORITE CABLE CHANNEL ?
Dear Customer
Sir/Madam the memory of the content(TV) is to store about only thirty channels so u can not able to store more than that,if in case you want clarifications just get linked with below site which may help you sometimes.
http://www.northjerseymall.com/Mall/CommonPages/contactv3.asp
Thank you
Dec 15, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Woody Woodcasters@hotmail.com
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
