Question about Cycling
How to replace battery terminal on a yukon trail navigator sm24 electric bicycle
  • Cycling Master
  • 1,189 Answers
The terminal on a battery is typically permanent.
Posted on May 08, 2017
I am having trouble with fuse for bike. I lost a little clip that goes to inside of fuse box, is this a problem? looked like it might have been copper but I don't know about electric issues?
When you feel a lot of heat around connections of any kind, fuse or whatever, that usually implies a resistive connection at that point. This is usually caused by corrosion at the point where you experience the heat. Look for corroded contacts and clean them up.
Just a loose connection can cause heat as well. Make sure electrical connections there are good.
Nov 30, 2015 | Navigator SM24 - Urban Street Electric...
How can I purchase the battery
you'll need a lead acid 24 volt, 10 amp hours battery. Amazon has them or try Batteries Plus.
Oct 28, 2015 | Navigator SM24 - Urban Street Electric...
How do I get the headlight to work?
Is there voltage across the wires leading to the light? If so, the light is burned out. If not, check continuity from the ground side of the light to the battery (-) post. If it is good, check for battery voltage on the + side of the light when the switch is on. If there is no voltage there, follow the wiring back through the switch to the battery + and determine where it is good.
Sep 10, 2015 | Navigator SM24 - Urban Street Electric...
How do i replace the battery on a 2000 GMC Yukon Denali
Remove the battery hold down located on the front side of the battery. Remove the ground terminal. Remove the positive terminal. Lift battery out.
Feb 20, 2015 | 2000 GMC Yukon Denali
Yukon trail not installing windows 7
yo dipshits... he asked about yukon trail.
Aug 03, 2012 | The Learning Company Yukon Trail
How do I fix a 1963 Ross Europa 3 speed bicycle headlight? I opened it up and I see a couple of wires leading from the switch have been cut from the battery holders. I'm missing a spring on one side of the...
A headlight is not electronics. It is a very simple electrical circuit. One wire goes from the switch to a terminal/spring on one battery (let's say the positive terminal). There's a metal or wire connection between the two batteries, and then another wire goes from back from the other battery's terminal (negative in this example) to the switch. There's no significant value in the headlight, as they weren't original equipment on the bike, so you can just buy a replacement light.
Aug 30, 2017 | Blackburn Flea Front HL Bicycle Headlight
Cycling Logo
46 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
