Question about Yamata Sewing Machines
I have a second hand Yamata FY7568 sewing machine, and the bobbin tension is too tight. The instruction book says it is factory set and does not need to be altered. What can I do, please?
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I was also looking for yamata manual can:t get it on internet but got it from Ricoma you can mail them on service@ricoma.us and the will send u the pdf file may be a fee if you didn:t purchases the machine from one of there dealers
Posted on Jul 06, 2017
I have a YAMATA fy14u4ad, but I don't have the book to tell me the thread setting so what should the thread setting be for all 4 threads
Assuming this is a 4-thread serger. The thread tension setting will depend on which stitch you are making. A standard 4-thread overlock stitch would generally have the tensions set in the middle. FWIW, the tension in this setting is correct when the threads meet in the middle of the fabric. It should neither be off the edge of the fabric or so tight as to create a puckered edge.
Aug 10, 2017 | Yamata Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
How do I adjust the bobbin tension on a mademoiselle 300 sewing machine
Take out your bobbin case Hold it in front of you until you can see the little screw head
Mark down on a piece of paper at what o'clock the screw head is sitting ie look at the screw head as a clock face and see where the time is!!
Then left turn is to loosen the bobbin tension right tun is to tighten the tension.
ONLY move the screw head about quarter turn each time, mark where on the clock you have moved it to
Put back in machine and sew, check stitches Take out again and follow above instructions do again. Most times it only takes a couple of tries to get it right.
. The stitches should be even on the top and on the bottom. Sometimes if you are using a thicker thread in the bobbin it can be tricky These instructions are the same for what ever machine you are using. Sometimes in your instruction book there are how to's on setting the bobbin tension. I hope that this can help you Dot
Mar 05, 2015 | Brother Sewing Machines
The thread keep bursting as soon as i start to sew although machine is thread properly
Check your thread tension isn't too tight, try on a piece of similar fabric that you are going to use, try sewing a line of stitches, if the thread snaps, change your tension number, then sew another line with your different tension number, try this until you can stitch without the thread snapping, it could be that your bobbin tension is too tight. Can you check your machine manual, it could even be the needle or the thread that's wrong for your fabric. But I would say, check your tension.
Hope this helps.
Apr 02, 2014 | Yamata FY811 Mechanical Sewing Machine
No tension on the bobbin and no way to set it the book says it is factory set. maybe it is just worn out. it is plastic.
It may be factory set but it cannot determine the type of thread you use, on the bobbin case there is a screw if the thread does not pull through with slight resistence and is tight then slacken the srew anti clockwise about a quarter of a turn and test, repeat if necessary, top tension 4 or 5
Aug 07, 2011 | Simplicity Sewing Machines
Yamata FY7568 Machine not sewing
Make sure the correct needle is installed on the machine. Domestic needles will have one flat and one rounded side on the shaft. Make sure the flat side of the needle is on the back and the groove on the needle also being to the back.
You might also want to make sure the tip of the needle is not broken.
Other than that, your machine could be out of timing.
Jun 19, 2008 | Sewing Machines
Sewing Machines Logo
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
