Question about GE Refrigerators
I have a GE GSS23QGSABB refrigerator and the flap won't close all of the way after dispensing ice. How can I tell if I need just a new flap or a flap and solenoid?
HVACRH20
  • 237 Answers
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Posted on Jan 08, 2007
the dr
  • 447 Answers
SOURCE: Ice Dispenser - in door
Yes that repair is quite common and not too difficult you need a Maytag Fountain door Kit dont have the part# hear but can be researched available at all appliance part retailers........comes with the solonoid, new flapper door and outher redesigned pieces also an instrunction sheet A solved rating is great motivation to continue giving priceless advise........
Posted on Oct 03, 2007
  • 1122 Answers
SOURCE: Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Posted on Apr 14, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
aasc
  • 1606 Answers
SOURCE: ice dispenser door flap will not close.
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Posted on Sep 02, 2009
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
My GE refrigerator tfx25zp water and ice dispenser sticks for 2-5 seconds after removing a glasss.
most of the new ice dispenser flaps have a 2-5 second delay before they close themselves this is normall operation.
Feb 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice dispenser in my GE Artica is clogged. There is frost and ice on the dispenser and at the top of the chute. What is the problem?
The dispensor flap is not closing . Usually the flap solenoid rusts causing non closure . When not closing , warm air is sucked in by the fan , causing frost . Without model number , cant give you the part number you need . Solenoid and plunger is the part name .
Aug 09, 2009 | GE Profile Arctica Stainless Steel Top...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
