Question about Samsung Televison & Video
SAMSUNG TV MODEL LN40B630NIFXZA, PICTURE IS DARK, IS IT THE BULBS AND DO YOU KNOW WHERE I CAN GET REPLACEMENT BULBS OR SOMETHING ELSE IF THATS NOT THE PROBLEM
ctf1800
  • 4402 Answers
SOURCE: samsung HC-p4241w- replacement bulbs/screen
http://www.fixyourowntv.com/projectionclean.php
Posted on Jan 28, 2008
  • 1694 Answers
SOURCE: 46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Posted on Feb 05, 2008
yankeegurl
  • 121 Answers
SOURCE: samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
SOURCE: Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Posted on Jan 11, 2009
phongnv
  • 56 Answers
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Posted on Feb 16, 2009
I have a 55in Samsung Dlp the color looks good but a little dark can't see picture if the movie is dark
You might need a new bulb, the bulbs get dim as there life diminishes. Replace the bulb to get a bright picture. Do not use cheap bulbs, an OEM bulb for that tv should be $60+. . Cheap clone bulbs will work but will fail a lot sooner
Feb 19, 2015 | Samsung Televison & Video
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
Hello, My picture has gotten very dim and dark. I was told my bulbs need cleaning. How can I do this by myself or do I have to hire someone to do this for me. Thank you, Debbie
Its more likely that the CRT coolant needs replacement. Thats vert famous for that model. The CRT coolant gets messed up and the CRTs cant project the image properly so it gets a dull picture and the color tints are wrong.
Sep 01, 2011 | Philips Magnavox 51MP392H Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
My samsuNg PS42A410C1D has no picture. i cant bring up any menus or anything see anything but it is producing sound
The most likely thing is that your screens backlight or inverter has gone faulty.
When you turn it on, you may be able to see a very very dark image of something (best seen by activating the TV menu). On some screens the picture is still far too dark to be visible though.
With this kind of fault, its down to fitting a new inverter, and if that doesn't cure it, then fitting a new backlight bulb (or bulbs) will sort it out, but these are not jobs that can be done without some expertise at them.
Most TV inverters are large circuit boards inside, and take about 20-30 minutes to change as the whole TV has to be dismantled, but the backlight bulbs are much more complicated (and extremely fragile too).
Unfortunately, there's not much else that can be done except trying changing those 2 parts. Although its possible for the screen cable inside to become disconnected and lose your picture, that results in the screen lighting up brightly (usually pure white if the cable comes off completely).
Apr 27, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Samsung LE32R41BD - no picture, only a very dark blue screen
yes go to www.shopjimmy.com get the main board of your tv and replace it lcds usually have 2 power supply and the main one thats the problem tv repair man told me it incharged of all your inputs sound and picture but he was charging too much and the manufacturer too 149.00 shop jimmy 108 with shipping glad too help you and you r welcome and it aint no science to do it your self do it on top of your bed thats how i did mines in order to get the model number have to be real careful with the screen oh and you r welcome
Apr 13, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Dull / dark screen and picture quality not sharp
The cooling fluid in the blue and perhaps the green picture tube assembly has become contaminated. Only solution is to remove the assembly and dump old fluid and clean and reinstall new fluid.
Apr 30, 2009 | Televison & Video
Rear projection tv screen is dark
This unit does not have bulbs it has tubes.What is happening is the coolant fluid in the picture tubes is contaminated with a fungus( blue and green).A repair shop should be able to fix this problem for about $250.I do not recomend fixing this problem youself,but when it is fixed this unit will look like new
Jan 12, 2009 | Televison & Video
TV has dark streak on one side of screen.
Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
Dec 13, 2008 | Samsung HL-S5687W 56" HDTV
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Open Questions:
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
