Question about The Computers & Internet
Two sides of a triangle measure 14 units and 6 units in length. Which number represents the length of 3rd side? 6,8,9,21
    Habit-Forming:
  • 44 Answers
9
because the other 3 numbers ARE IMPOSSIBLE !
Posted on May 09, 2017
If the length of hypotenuse of a right angled triangle is 5cm, its area is 6 sqcm. then the length of the remaining sides are
The Pythagorean Theorem states for a right triangle
A squared + B squared = C squared
where C is the hypotenuse.
if the hypotenuse is 5cm, then the remaining sides have to be 3cm & 4cm
Also called the 3,4,5 right triangle.
Sep 11, 2017 | The Office Equipment & Supplies
The triangle has 3 congruent angles. does not have a ruler to measure the lengths of the sides. How can she show that the triangle has three congruent sides?
Three congruent angles means it is an equilateral triangle, so by definition it has 3 congruent sides. Or, by the Sine Rule of triangles
a/sinA = b/sinB = c/sinC
and since A = B = C (given) then a = b = c.
Apr 08, 2016 | Computers & Internet
The diagonal of rhombus are 8 cm and 6 cm then the length of each side of the rhombus
https://www.mathsisfun.com/geometry/rhombus.html
Lesson HOW TO solve problems on the rhombus sides and ...
www.algebra.com > Geometry > Customizable Word Problem Solvers
  1. Cached
Lesson HOW TO solve problems on the rhombus sides and diagonals measures - Examples ... Find the perimeter of the rhombus, if its side is 7 cm long. ... Since all four sides of the rhombus have the same length, the measure of the side ... 32/4 cm = 8 cm. ... In our case the legs are 12/2 cm = 6 cm and 16/2 cm = 8 cm long.
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm ...
  1. Cached
  2. Similar
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm. What is the ... (paid link). Click here to see ALL problems on Geometry Word Problems ... We need to find the side of the rhombus using the Pythagorean Theorem. After that, we use ...
The diagonals of a rhombus are of lengths 6 cm and 8 cm. Find the ...
https://in.answers.yahoo.com/question/index?qid...
  1. Cached
  2. Similar
Jun 29, 2013 - The diagonals of a rhombus are of lengths 6 cm and 8 cm. ... rough aketch and you will see that in each triangle the shorter sides are 3 cm and 4 cm, so using the Theorem of Pythagoras, if we call the hypotenuse l cm, then l^2 ... Rhombus
Mar 30, 2016 | Office Equipment & Supplies
In a 4'x 4' square, cut into 2 triangles, what would be the 3rd side of each triangle?
Hi Carolyn
This is easy peasy.
A squared plus B squared = C squared
So, 4 squared (16) + 4 squared (16)= C squared
C= square root of 32 or 5.66
Link below provides a calculator so you can do it yourself.
-Steve
right triangle formula Google Search
Mar 12, 2015 | Computers & Internet
Offset is 8 in run is 6ft 3 3/8in travel is 6ft 3 13/16in. How do I find the degree?
If I understand your terminology correctly, you have a triangle with a hypotenuse of 6' 3-13/16" and a side opposite the angle you wish to find with a length of 8" (and a side adjacent to the angle you wish to find with a length of 6' 3-3/8") Trigonometry says that the sine of an angle is the length of the opposite side divided by the hypotenuse. (all units must be the same, so convert everything to inches)
So sine (angle) = 8/(6 * 12 + 3 + 13/16)
sine (angle = 8/(75.8125)
sine(angle) = .105523
angle = arc-sine(.105523)
angle = 6.0573 degrees (from tables, calculator, computer etc)
Jun 07, 2014 | CyberEd Trigonometry Problem Solver
Area of traingle with tree side
All triangles have three sides.
There are two main formulas that do not call on trigonometric ratios.
The classic one:
  • 1. You need the length of a base and it corresponding height (the length of the segment perpendicular to that base and passing through the vertex (summit) opposite to that base. Area=(1/2) * (measure of the base)*(measure of the height). The base and height must be expressed in the same unit.
Heron's Formula if you have the length of the three sides. Let those measures be a, b, and c.
  • Calculate the semi-perimeter p with p=(1/2)(a+b+c)
  • Area=Square root of (p*(p-a)*(p-b)*(p-c))
  • a, b, and c must be expressed in the same unit.
May 21, 2011 | Casio FX82ES Scientific Calculator
Find the value of x in the 45-45-90 triangle. write your answer in racial form
in a 45-45-90 triangle, the lengths of the sides are in a ration, 1:1:√2, so if you have one side of the triangle, such as a leg, with the value in the ratio of 1, simply multiply that given number by √2 to get the hypotenuse, if you're instead given the hypotenuse, simply divide by √2 to get the answer for one of the legs. The legs of a 45-45-90 triangle are equal.
I hope this helps!
May 05, 2011 | Computers & Internet
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
http://www.boschtools.com/AboutBoschTools/RequestProductLiterature/Documents/2010%20Catalog%20PDF/2010%20Measuring%20Tools.pdf
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
http://www.engineersupply.com/images/bosch-tools/Bosch_Digital_Distance_Measurer_130k_User_Manual.pdf
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
http://boschtools.com/Service/ContactUs/Pages/default.aspx
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
http://www.analyzemath.com/Geometry_calculators/pythagorean.html
Feb 19, 2011 | Bosch DLR130K Laser Distance Measurer
Computers & Internet Logo
53 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
