Question about Garden
PoulanPro 42" riding mower. Brake pedal seems sloppy and not tight?
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Posted on Apr 06, 2009
  • 53 Answers
SOURCE: how do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Posted on Jul 08, 2009
  • 376 Answers
SOURCE: Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Posted on Jul 29, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
Troy-bilt troubleshooting
Sounds like you have an issue with a broken or off pulley belt.
Aug 06, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
NORMALLY THERE IS A KNOB OR LEAVER FOR YOUR PARKING BRAKE AND IS CONNECTED TO THAT PEDAL BRAKE TO LOCK IT UP FOR PARKING, THROUGH A SERIES OF RODS CHECK THOSE RODS IF STILL ATTACH TOGETHER, PRETTY SURE THAT IS THE PROBLEM, GOOD LUCK
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
The brake pedal is pushed or the linkage is stuck in the "brake" position.
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mower will not go into geat either
That can happen if the belt comes of,it allows clutch pedal to over travel and if the retaining pin is not in the rod it can come loose. There is a 1/2 brake adjust nut on the actuator,if you remove that nut the actuator will come off and you can put it through the rod and reinstall it,there may be a actuator return spring that you may have to contend with but it is a fairly easy job, make sure you don't over tighten the nut,that is the brake adjustment,the actuator should have some play in it,if the brakes seem too tight after you install it back the nut off till they feel ok.
Jul 30, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
