Mieli washer novotronic #w1986 on and off button does not hold when pressed in. machine does not sart. what shall i do?
4 Suggested Answers
mrbobfixit
  • 259 Answers
SOURCE: When i depress the start button nothing happens.
Have you tried unplugging the washer to re-set the controls? Also double check to be sure that there is no water left inside the machine (blocked pump).
Not to overlook the obvious, but you did hit the "power" button first right?
If there is no water left and the unplug trick does not work, you may have a defective control board.
Posted on Jun 15, 2010
  • 2987 Answers
SOURCE: how often do i have to ask? i had put in the question already 3 times. again, Novotronick model #w1986 does not turn on the machine upon pressing the on and off button. what am i to do?
Hello Jacob Gutman,
Just the once... you have ... Only one here on FIXYA.
(presently "about Office Equipment & Supplies"
Just a SWAG (scientific guess) here...
This is posted under "OFFICE EQUIPMENT"
because your washing machine is in the ...
Den... Library (office??/)...
USA parts listing show this as a non-domestic
Miele ... (Volts: 208-240 Volts)
Power supply & cord is ALWAYS the FIRST THING
to check.
Second is your CONTROL BOARD.
AJ Madison does provide support for these
Happy hunting
Miele W1986 Super Novotronic Super Capacity Washing Machine Angled...
Carnac
Carnac the Magnificent
Posted on May 08, 2017
About Miele novotronec washer w 1986 door seal the rubber is ripped and water is leaking can I order a new seal and do I just remove and replace or is there a trick to it Thanks so much
Here is the part number for the seal 6816000 As far as the trick, depending on your level of skill, there will be a tab on the seal itself and that should be positioned at 12 o'clock. You press the seal firmly onto the drum until you hear a pop. The clamping ring which holds the seal on is 8 mm bulb which reusable. The seal has to be stretch over the outer metal casing.
Aug 18, 2011 | Miele Super Novotronic W1986 Front Load...
The digital timer skips 9 minutes out of the wash cycle. After starting the normal 140 degree wash cycle (46 minutes) the washer will start and wash normally until it has counted down to 41, then it...
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Jun 21, 2011 | Miele Super Novotronic W1986 Front Load...
I started a wash cycle, needed to add more laundry, press the pause/cancel buttom twice, now I can't start it again. When I press the start buttom everything goes blank, all lights go off
Remove the power plug and keep aside. Keep the sart button pressed on to discharge. After 15 minutes switch on the washer while holding the pause/cancel button.
If the set does not come back to life it iis possible that the main board has encountered some errors.
Repeat the procedure after some time.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
System locked
DONT KNOW THE UNIT BUT ALMOST CERTAINLY A SELECTION OF BUTTONS CAN BE PRESSED TO RESET BACK TO FACTORY DEFAULT SETTINGS. BOOK SHOULD DESCRIBE HOW.
Aug 16, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
