Question about Craftsman Garden
When i go to pull my craftsman mower deck to the full up position it hits on something and will not go into the top notch
    Top Expert:
  • Craftsman Master
  • 12,650 Answers
Look under frame and check attachment / lift arms for bent or damage and look at pin/bolt connections
Posted on May 08, 2017
Mower deck adjustment
you may have bent brackets in the front. These are the pieces that straddle front and back of the front axle beam. This happens when you hit things sticking up or on the side with the deck.
You also could have bent deck link bars (where you make height adjustment on the front).
Aug 12, 2014 | Craftsman Garden
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
May 07, 2014 | Garden
Deck may be bent?
On your problem it is diffiuct to say. I don't know how old it is and if it has been run hard in gravel or how many roots you hit. However if the blades hit it hard enough you may have hit the deck brackets. You need to get it no concrte so you can mesure the for corners of the deck on the level surface, then check which side and if it's front or back that is higher. Most likely the lowering arm Is what is bent where the lever you Drop the deck down with is, look tthere first. Also look at the top of the deck and side to side at the lawen mower and see if you can see if the deck is up higher on one spot more than anywhere else. . I know this is confuseing but hope you understand what I am saying. I would also check the front axle mesure the top o the axle on both sides are they even? Yes? then mesure from ground to top of the hood on the lawnmower. Good luck.
Aug 28, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman lawn tractor sudden no fire repiaced
Check for a sheared flywheel key. One way to check is to move the piston to top dead center and look at the position of the magnets on the stator in relation to the poles on the magneto. If the positions aren't very close at TDC, the flywheel key is most likely sheared, which is why you are not getting spark. Did the tractor blades hit anything hard lately when mowing? The key is made of soft metal so that if something like that happens, it will fail before the crankshaft gets bent or to prevent heavier damage. Anyway, you might want to check it out. Hope this helped and best wishes.
Aug 06, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Lawn mower has a loud noise like something is hitting on metal part.changed blade this year with no problems. loud excessive vibration when running.
Sounds like your deck may be bent in and the blade is hitting. Remove the sparkplug and tilt the mower back on the handle (I'm assuming this is a push mower) and have someone pull the rope while you watch the blade underneath. You should see the problem.
Aug 06, 2009 | Craftsman Garden
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Timing belt off my 5.5 push mower
it has a crescent shaped pin under the flywheel and is sheared causing the timimg to be off and pull your arm out of the socket
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
