Question about NEC Office Equipment & Supplies
Nec np400 no display orange status light flashing
welcomejee
  • 10594 Answers
SOURCE: NEC VT440 projector problems can you help
Please check its vantilation fans, are they rotating or not?
Posted on Jul 24, 2008
SOURCE: power light flashin orange, status
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Posted on May 13, 2009
  • 4 Answers
SOURCE: Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
Posted on Sep 15, 2009
heathgr
  • 442 Answers
SOURCE: I have a NEC VT470
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Posted on Mar 03, 2011
  • 5370 Answers
SOURCE: Hi i have a nec vt595 and i just changed the bulb
Check the screws are all screws properly fitted.Also check if you have re -fitted the lamp cover properly and fitted the screws properly/.If the lamp cover is not secured properly then new lamp will not get detected. After the lamp is replaced.You need to reset the lamp hours. select the menu then ---reset then--- clear lamp hours ---- to reset lamp usage hours. ------------- The power light is orange.This means that projector is cooling down.----------------- The status light is blinking red.This means that there are few possibilities.How many times the light is blinking count that.------- 1) If status light is just blinking 1 time.This means that lamp cover is not properly closed or the lamp housing is not properly fixed or the lamp housing is got shorted.the new lamp has to be placed properly,other wise it get burned in few minutes.Check the lamp placement and lamp cover fitting.If any thing is not properly seated then the status light blinks only one time.----- 2) If the status light blinks 2 times then its temperature error,the projector needs to be placed in cooling area like in the ac room or near to cool place like near the open window.Or you can externally place the fan to the back of projector.This cools the internal overheated temperature.This has to be done if there are 2 blinks on status indicator light. ---------------- 3) If the status indicator light blinks 4 times then its internal fan error.The fan is not working.There is a fan in the projector.This fan cools the lamp assembly and controls the temperature.If this fan stops running then lamp gets over heated and temperature increases and status light will give indication by 4 blinks.Many a times fan gets obstructed by dirt collected inside or the ventilations in the projector gets blocked.Check the ventilations too.---------- 4) If the status indicator light blinks 6 times then this is indication of lamp error.Turn the projector off,remove the lamp and reconnect it properly then turn it on again. -------------------------------------- If the lamp indicator light is blinking or steady red,then this is indication of lamp replacement.---------- But as you mentioned that you replace the lamp so lamp is new.In some cases new lamp comes faulty.Get it replaced.But if lamp is ok then check the fan, the ventilations,the placement of lamp.Place the lamp to cool place.Check the lamp and lamp cover fittings. Every thing should be proper.But if all things checked out ok then yes your replacement lamp is faulty.You will have to get it replaced.Always buy original lamp,in case if you have ordered compatible lamp,then in some cases compatible lamp will not support your projector.The original always works. ---------------- If you require user manual for your nec projector then click the link below:--- http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf ----------- the troubleshooting guide is mentioned on page number 55.------------ This should help.thanks.Helpmech.
Posted on Mar 05, 2011
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
My nec vt595 wont start up the status light is flashing orange
The only time the "status" light will be orange is when you accidently press the cabinet button and the cabinet is locked.
However, if the "power" light is blinking orange it means that the projector is cooling down and you need to wait a few minutes.
Jan 03, 2010 | NEC Computers & Internet
Power light flashin orange, status light flashing red on WT610 NEC
Jan 25, 2009 | NEC WT610 DLP Projector
Status indicator blinks RED, not starting.
There are different rates at which the status light will blink to indicate various errors. See manual (link below) page 49 http://www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT37/vt37_manual_e.pdf
Jul 29, 2007 | NEC VT37 Multimedia Projector
Feb 13, 2007 | NEC MultiSync VT45 Multimedia Projector
111 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
