Question about Samsung Televison & Video
Samsung led tv buzzing noise
Tv hums/buzzes even when tv is muted. Almost sounds like a vibration type noise but nothing I've checked is loose. Also, no sound bars connected to tv
SOURCE: sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
Posted on Mar 11, 2009
  • 125 Answers
SOURCE: my lcd tv makes a humming noise
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Posted on Mar 14, 2009
  • 92 Answers
SOURCE: Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Posted on Sep 12, 2009
Testimonial: "Quick response, i will check it out asap"
SOURCE: problems with sound that buzz/vibration sound
me too, check in the menu Video/Picture settings and press down backlight...
works for me.
Posted on Feb 25, 2010
SOURCE: Have just bought an LG37LD450. Buzzing noise
Had this problem as well. Ran through a laundry list of possible solutions. Finally found that the key is to increase the backlight (Access via [Menu] [Picture] ) to 100% and the noise goes away. If this is bad for the life of the backlight, just pray the backlight burns out inside year 1 while the warranty is still valid!
Posted on Mar 06, 2011
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ... > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from
High pitched sound coming from my Samsung DLP TV - Open Forum ... > Forums > Social > Open Forum
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
? 9:23
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help -
Dec 30, 2015 | Magnavox Televison & Video
Lg lcd tv buzzing sound
You have problems on the sound portion of your board. It could be a bad solder joint causing it to arc to another component or to ground. It could also be just a plain ole bad Amplifier or something. When you mute it you turn all the voltage off to your AF Amps and naurally the noise will stop. Find the sound board and check it for cold solder joints.
Dec 03, 2013 | Televison & Video
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Buzzing/humming sound from rear of TV unaffected by volume settin
I think you have problem with the main digital PWB
You need change that part.
Nov 18, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
SanyoDS25390 Tv good picture buzzing noise
What are you using as a source? If its a cable/satallite box, double check that first. If its a video input or a scart input, swap out the cables. If it still there you could have an input problem or a filter capacitor going bad. Does the hum get louder with sound? If it does it is an input source and or cables. Good luck Ps please dont forget to rate this thread.
Nov 25, 2006 | Sanyo DS25390 TV
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
