Question about Dual Car Audio & Video
What kind of wire harness will I need to install an aftermarket double din dual 7in touch screen cd/DVD/Bluetooth player in my 2003 Pontiac bonneville
  • 611 Answers
SOURCE: 2000 pontiac bonneville wiring harness
u can get one to use out of a srvice book at the libruary
Posted on Jun 15, 2008
SOURCE: dvd player wont show picture
To fix this issue on the back of the double din touch screen#uv8020, splice the pink wire, and splice into the (black) ground wire connecting them together. This will enable you to watch dvd;s whie driving.
Posted on Jan 24, 2009
simard2
  • 124 Answers
SOURCE: I NEED A COMPLETE WIRING
Go to the Following website.
http://cgi.ebay.com/Alpine-Power-Wire-Harness-CDA-9884-CDA9884-CDA9847-Z03_W0QQitemZ400020850727QQcmdZViewItem
Posted on Jan 28, 2009
  • 10 Answers
SOURCE: double din radio doesn't fit in dash
i have a 2002 ford escape and i bought a double din radio and it did not fit and found out it is actually a din and 3/4 with out serious mods (cutting a bigger hole in dash) double din wont fit i bought a single din stereo and a din a 3/4 dash kit works fine
Posted on Jun 17, 2009
budice7h20
  • 93 Answers
SOURCE: 2005 Pontiac Sunfire aftermarket audio system install
You can go to Walmart and in the stereo/speaker department they have dash kits for different vehicles.Just read the box to determine your vehicle. Also, they have amp kits for different wattage amps, but if you had rather buy each item you will need, a Power Wire (to the battery 4g or 8g), a ground wire (to the chassey), a remote wire that should run to a wire from your cd player saying remote (any size is fine), speaker wire (14g or 16g is fine) a set of RCA cables, and if your cd player dosnt have RCA jacks you will have to have a converter.
Posted on Jun 27, 2009
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
NEED WIRING DIAGRAM
If you are referring to installation and have the aftermarket wiring harness, The wires should be color coded. RED, YELLOW, & BLACK are power, ignition and ground. These should correspond to matching wires on the back of the head unit (CD player). Match the colored wires from the back of the unit to the same colored wires on the aftermarket harness and then connect them using wire connectors/wire nuts. Once you have them into the correct order the aftermarket harness should connect into the harness in your vehicle. I hope this answers your question =)
Nov 05, 2013 | JVC AM FM CD DET FACE CAR STEREO
Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Sep 24, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
I cant use the bluetooth on my Kenwood Excelon DNX7120
The Kenwood Excelon DNX7120 doesn't have Bluetooth integrated, in order to use, for exemple, a bluetooth phone you need to install a
Feb 28, 2010 | Kenwood Excelon DDX-7015 Double Din Car...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Will this stereo work in the cavalier?
You will require an installation kit. Your car has a double DIN opening and the AR5500 is single DIN. Other than that, the installation should be as normal aftermarket.
You'll also need a wiring harness. According to Installer.com, the Metra part number is 71-2003-1.
Mar 25, 2009 | JVC Arsenal KD-AR5500 CD Player
Dvd player wont show picture
Jan 22, 2009 | Phase Linear UDV9010 Car DVD Player
Car Audio & Video Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
