Question about Stanton STR8-150 Turntable
Stanton str8150 decks. motor problem
Hi, im just windering wether ther is a fault with the motor in one of my decks. I can play a record for around a minute and then the motor cuts out hence the record stops playing, however the lights are still on. Shall i take it back to the shop or is there something im doing wrong?
  • 515 Answers
If it stops after a minute of rotation, then there is something wrong there. If it's brand new, I would say return it, or send it in for warranty repair.
- DJ PRO AUDIO
Posted on Nov 22, 2007
When playing LP the sound is bass heavy, but when playing a cd, the sound is perfect.... any suggestions?
The record deck is played through a separate pre-amp to all other functions, so it therefore could be a fault in that pre-amp, but I doubt it. You can fit a wide verity of cartridges in record decks that will each give a different response to the sound. But first check that the cartridge connections are correct. Try swapping them around, it might change what you get. But it could simply be that you have a cartridge that produces a lot of bass. Changing the cartridge to a high quality recommended type - by say some hi-fi buffs website or magazine, might solve the problem.
Apr 14, 2015 | Pioneer PL990 Turntable
Stanton ST 150 motor will not turn on but all lights on deck flash?
If you have misc LEDs that are flashing without due cause and a motor, I'm betting a Direct Drive motor, that won't spin, I would same you have a damaged microprocessor(computer) within your table that's bad. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 13, 2013 | Stanton ST-150 Turntable
Stanton str8 60
The Stanton STR8-60 is a direct drive record deck, so this shouldn't happen unless the platter was damaged but after a little research I found that the Stanton's can get a faulty chip which is meant to regulate the speed and therefore can make it spin erratically.
Jun 14, 2013 | Audio Players & Recorders
Stanton deck issues
Does decks are too bad build, i gave them away
Jul 23, 2012 | Stanton ST-150 Turntable
Hey guys I purchased the Stanton Str8-80 in 2003 and used it actively for the following 1 or 2 years. Shortly after that, I left it in a corner to collect dust and only recently, I started to use it again....
If the turntable has a belt drive, the belt probably has failed. If direct drive, the motor may have failed. Only a cheap turntable would have rim drive that failed. Your Stanton is not one of them.
Apr 26, 2017 | Stanton STR8-80 Turntable
How do i fix my turntable when the output is working on the right hand side but not the left
First - Has the cartridge failed, or has a wire become lose to it? Have you checked the cable comming from deck?
If you have or none of these gives solves the problem, then try reversing the leads on the cartridge so the good ouput gets the missing channel. If you still can't hear it then there's a electronic fault on the left hand channel pre-amp inside the record deck.
Oct 19, 2009 | Stanton T.120 Turntable
Stanton c.304 cdj reading disk but cant go bno futher
Check the sled motor is operating correctly.
Aug 05, 2017 | Stanton C.304
Humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
Feb 19, 2008 | Stanton STR8-150 Turntable
Stanton STR8-150 Turntable Logo
268 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
