Question about LG Televison & Video
Lg 47cm575 will not turn on
Red light comes on but no picture. Remote will not turn it on either. I already replaced the power board and it still did not help. I am getting 110 out of out to tv.
SOURCE: replaced lamp but no picture after 15 seconds
What is the price of that and what did they do.
Posted on Dec 31, 2007
  • 132 Answers
SOURCE: power light comes on,clicks before picture comes on then shuts of
Yes, it is either that or the "Startup Circuit" is faulty usually it is the associated relay. Thats the clicking sound you hear. When you turn on the TV, the relay is activated along with a timing transistor, the Relay has to make contact within a certain time frame. If the contact is not made during that time frame, the TV shuts down. This is a safety feature in all TV's. If you can get a schematic it will show you where the relay is or, after you unplug the TV and wait 15 minutes, you can take a look inside at the main circuit board, sometimes they mark the area with either "START UP" or "SHUT DOWN" and there you should see a relay.
But a new one usually has to be soldered in.
Posted on Mar 26, 2009
SOURCE: Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Posted on Aug 13, 2009
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
  • 8617 Answers
SOURCE: Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Posted on Mar 02, 2013
My LG 55LB6300 takes 30 minutes to get a picture after turning it on and light is on.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 02, 2016 | LG Televison & Video
Why is my TV turning off by itself?
Change the main IC from main board
May 01, 2016 | LG Televison & Video
JVC LT40A320 turns on but no picture. Replaced Power Supply & Backlight Inverter (TV was hit by a lightning surge, would not do anything at first) now the green light comes on but no picture or sound.
Since your TV was struck by lighting, the power supply is the first board that gets affected by the sudden change in AC power.. The main board is the next board due to the fragile components and the excess of voltage that is supplied to it when the lighting happened. Since you have replaced the power supply already.. I would suggest to replace the main board and that should restore the functionality on your TV.
Sep 04, 2015 | JVC Televison & Video
Mar 02, 2013 | Samsung Televison & Video
Hi,I have a LG rear projector 56DC1D tv.Power had to be turned of from mains for about 4-6hours.Turned power supply back on operated the remote to turn on all good until it switched off on its own.Did it...
The lamp has already a resistance which is sense by the processor and made the unit a subsequent shutdown. It will produce an overload to the ballast board which is detected by the processor. Replace it with new one and your unit will back to normal again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 21, 2011 | LG Televison & Video
Tries tv unplug,replug it back like about an hour later for the tv resetting itself back to the factory setting.Tries again,tv should be working.If still getting no power at all than the tv Tuner board is dead,because pictures freezing and dies completely is the causes so it is not power supply board problems.The tv Tuner signal board is the causes,that the board where the incomming broadcasting signal cable plug into it.Tries websites like, to buy a refurbish tv Tuner signal board for the replacement.
Feb 17, 2011 | LG 42LC2D 42 in. LCD HDTV
When I turn it on (with remote) it goes from standby mode (red), the light flashes, then I hear a click and the light stays on white but I cannot get a picture. I have to turn the telly off and on several...
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites, for a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 42PX4DR 42 in. Plasma TV
No picture on LG Flat panel and no sound. Only
know how to sloder?Replaced parts like capacitors burst open or puff up in the power supply.Or replaced the whole refurbish power supply, to buy.
Jan 14, 2010 | LG 27LC2R 27 in. LCD TV
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Televison & Video Logo
41 people viewed this question
Computer Repairing
Computer Repairing
