Question about Acer Aspire One AOA110-1588 Notebook
My fan makes so much noise especially when i play video.Can someone help
The problem with fans is there really isn't much you can do with them. Normally they begin to make noise as the bearing assembly begins to wear, or it might just need to be cleaned. In either case you need to crack open the case on your laptop, then you can inspect the fan. You can try cleaning it at that point, but usually its easier just to replace it. The reason why it makes more noise when you play videos is because video media requires more system resources to run, which also generates more heat. So, while you have your laptop open you may want to check your video card (which should also have a fan) and make sure that its clean. A dirty video card will **** out a lot earlier than it should.
Posted on Jul 25, 2009
  • Acer Master
  • 32,281 Answers
The fan could have a dry bearing problem and could stop spinning and cause the CPU to overheat and shutdown. The fan needs to be replaced and the dust removed from the fan/heatsink assembly.
  • 375 Answers
It is getting hot - make sure that all the vents are not covered. Use it on a desk or large book, rathewr than resting on cloth.
Video places a big load on the computer, which makes it run hot. The fan is running to stop the computer melting. Be grateful it is running :)
The Acer One isn't the best designed laptop out there - components are cheap, that is why the fan is noisy.
PS4 makes a high fan noise ?
It might be hot turn it off for at least an hour
Aug 07, 2014 | Video Game Consoles & Games
Ok so i have a problem with my xbox 360 slim i recently bought call of duty ghosts and i played it for about a month about two to three hours a night three to five nights a week recently ive tried playing...
Try blasting some compressed air inside near the fan (when the console is off and cool) If not, there is either something lodged pretty good in the fan or the fan is failing. Both would require you or someone to open the 360. Cheap fix though, considering the overheating hasn't taken too much of a toll on the hardware.
Mar 21, 2014 | Video Game Consoles & Games
Have a 2.26Ghz Celeron D, Intel 865 chipset, 750MB RAM.....everything was going fine until some days ago, all of a sudden, began experiencing overheating.....the CPU temp used to be around 45 celcius...
Other than the compound being dried up, or the heatsink not sitting properly on the cpu, the only other common cause of overheating is a clogged heatsink or fan, especially if someone smokes around the computer, the best way to fix this is to use a can of compressed air to blow the dust out from between the fins on the heatsink as well as the fans. Other than that fans will usually begin to make quite a bit of noise before they begin to fail, but it is possible for them to slow down over time, as a last resort you can try replacing the fans. ( be sure to check not just the one on the heatsink but the one on the power supply and any others providing exhaust to the case) You can also try using compressed air as well as a vacuum cleaner on the power supply to increase the airflow through the case.
hope this was helpful.
May 31, 2011 | Intel Celeron D 315 2.26 GHz (533 Mhz)...
My wii is making a whirring noise. Still reads
This is no doubt your system fan. it may be dusty and now having some trouble doing what it does. compressed air should clean this for you, unless you want to open it and manually clean the fan.
Hope this helps you.
Jan 04, 2010 | Nintendo Wii Console
My Ps3 makes a loud fan noise after 15-20 minutes
its your backup fan turning on you must not have adequate venitlation take it out of small place and put it near a fan or window
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Wii makes strange noise when trying to play games
it does that main is brand new and it does the same it noting
Jun 28, 2009 | Nintendo Wii Console
Noisy fan
well most likely an overheat try looking at the manuals if not contact nintendo
Apr 12, 2009 | Nintendo Wii Console
Acer laptop sporadic fan/dvd drive noise
it is quite normal especially if you are running processor hungry applications, or down loading video files
Aug 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
PC Noise Problem
the noise will be excessive dust on the heatsink fan or the extractor fan, gently hoover off the dust, if after that the noise continues the bearings in the fan are failing and a replacement will be required.
Nov 06, 2007 | Computers & Internet
Really Loud Fan Noise
They have a bad issue with that. The fans fail all the time inm those clarions... I can sell you a used fan for $40 or if youd like me to repair your unit you could send it to me and i will repair it for a total of $200. ampman out!
Dec 13, 2006 | Clarion VRX755VD Car DVD Player
Acer Aspire One AOA110-1588 Notebook Logo
615 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
