5 diffirent tipes of proper nons - Computers & Internet
What tipe of battery does it take. The battery that was in it quite and does not reset it self.
normally AA OR AAA BATTERYS. OR UNPLUG IT AND TAKE IT TO A LOCAL RADIO SHACK AND THEY WILL SET YOU UP WITH THE PROPER BATTERIES AND PUT THEM IN FOR YOU IF YOU ASK THEM TO.
Jan 14, 2015 | Audio Players & Recorders
Some keys won't tipe
have your laptop professionally cleaned by a reputable service center.dust and debris build up under the keys can prevent them from working properly. Alternately, if you dropped the machine, it is possible you have partially dislodged the cable connecting the keyboard to the motherboard
Aug 18, 2014 | Computers & Internet
My little sister putt coca cola over the tiping pad of my mac book. Now the tiping pad tipes only tall letters and went to the save system mode. My keyword are numbers and my mac dont accept this keyword....
Bring your Macbook in for repair. Continuing to operate your machine with sugary residue in it can easily burn up the logic board. There is no owner-level fix for a problem of this magnitude.
Jul 12, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
WHY IS MY 1998 BUICK P.AVENUE'S SPEEDOMETER NOT WORKING PROPERLY? WHEN I'M DRIVING AT ABOUT 35mph.IT READS 70mph.ALSO WHY IS THE km/h LIGHT ON AND WHY IS MY HEAT READING DIFFIRENT NOW IT READS IN CELSIUS.
You have your car converted to metric not SAE. Look in your manual it will show you how to change this back to SAE. Usually with the "mode" button you can do this but im not 100% sure on the park ave
Mar 02, 2010 | 1998 Buick Park Avenue
No spark to plug already try diffirents plus
It have done a test to check and see if the ignition module is working. And by your result it is not, you will need to find the engine numbers on the blower housing to start to find a new one. J19lm is the proper plug.
I would also check the control cable to make sure it is pulling back far enough to open the stop switch on the motor.
Dec 11, 2009 | Mtd 22" Yard Machine Push Mower
What tipe memory that i want to use it with this motherboard P5RD1-VM
Your motherboard takes DDR PC2700 or PC3200, non-ecc, non-buffered RAM. It has a maximum of 2GB. (1GB per slot)
See all information at:
http://www.crucial.com/store/listparts.aspx?model=P5RD1-VM
Thanks for using Fixya.
Nov 12, 2009 | ASUS P5RD1-VM Motherboard
Keyboard layout
possibly enough there is aproblem with the keyboard commands on your computer. go to conttrol panel =printers and other hardware=keyboard=hardware=troubleshoot.
problems with regard to key comands would be enlisted there, choose the one you have and info about how to troubleshoot will be given to you.
if that does not help, please send me a comment and i will consult a specialist to provide immediate assistance on email program.
thanks,
wonder
Sep 18, 2009 | Dell Sk-8135 Keyboard
The clutch and flywheel is bad in it. it is not going in gear. and will not shift.
IF PROPER PROCEDURES WERE FOLLOWED WHEN CLUTCH WAS INSTALLED AS THIS IS A PULL TIPE CLUTCH AND YOUR FORK WAS OK AND NO WEAR ON SHAFT OR SPLINE YOUR PROBLEM IS HYDRAULICS IT ALL LIES IN THE TRAVEL
Jul 15, 2009 | 2003 Hyundai Tiburon
Crystal eye web cam
check the driver at device manager if it's properly installed a yellow exclamation point means problem
Dec 17, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
