Question about Garden
Yamaha golf cart engine, 4 stroke, carb spitting gas?
Runs perfect, but air filter soaked in gas. fixing for a friend.
  • 72 Answers
SOURCE: 19 hp Twin Briggs and Stratton engine floods after a minute
Replace the float, sometimes they get saturated and look fine but are'nt. Also clean out the jets and bowl. The needle and seat may be worn as well. In other words, rebuild the carb. This time of season, after the equipment has been sitting all winter, I rebuild 25 or more carbs a week. It should cure your headaches, and solve your problem.
Posted on Jun 08, 2009
  • 3600 Answers
SOURCE: 4 stroke Yamaha 50HP -Runs rough at all throttle levels
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
Posted on Jul 18, 2009
  • 115 Answers
SOURCE: 2003 yamaha 50hp 4 stroke, won't start
sounds like you are going to have to pull carbs off and clean jets also check tank and line for debries
Posted on Sep 03, 2009
  • 174 Answers
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Posted on Nov 12, 2009
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
SOURCE: 2004 v twin 16 hp 500hours on it runs but spits
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
Posted on May 05, 2010
Yamaha golf cart carb spitting gas
Check the float in the carb, prolly stuck.
May 08, 2017 | Golf
My golf cart has to crank more than necessary before engine starts. Choke does not seem to make a difference.
The carb choke circuit is most likely plugged which is why it has slow starting. The clunk may be from the engine idle being set to high. It probably is running high idle because it has carb issues and the fuel system may need cleaning.
Oct 14, 2015 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Motor runs but cart won't go
1 check and clean fuel tank and lines
2 clear air filter, soapy water air dry then apply any air cleaner oil
3 adjust carb / chock
4 check for proper spark replace plug (2.99 )
5 make sure drive belt in good working order.
odds are the carb chock should fix you right up
May 23, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Yamaha golf cart
Look under the seat for a pressure switch.
Mar 26, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Oil and fuel blowing out through top of motor in yamaha golf cart 4 stroke engine
Engine got to much oil in it? Worn engine allowing fuel down into engine diluting the oil and raising the oil level? Blocked engine breather, pressurising the crankcase. Oil change and clean the breather. Worth a try
Jan 10, 2013 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
EZGO 4 stroke petrol engined golf cart how do you service it
Change air filter, oil, spark plug, cable to battery, When changing the oil, there is no need for a new filter. Just wash the old one with carb clean. Held in by 3 small bolts beside the drain plug. Check the rear end oil (90 weight) use the upper plug. Fill till it runs out. Grease the front end. Change the fuel filter. Drain the carb if it is going to sit thru the winter.
Oct 07, 2011 | 1995 Volkswagen Golf
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
