Telefunken Serial no. 102014156. My daughter pressed memory recall button and the TV went off and wont come back on.
Please help and where can I get a new power cord for this TV. Thank you Meryl 0842072873
  • 68 Answers
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
SOURCE: Programming GE corded speakerphone
I fixed this just now on my phone, while seeking a solution here.
- Do not do what you'd think... putting the phone and name info first. It looks like it will take this info but it won't. That's where the frustration comes from.
- Dial the PHONE# FIRST.
- THEN click STORE.
- Then click the location (A-C or 0-8... save 9 for 911 if you don't have a red emergency key).
- Then click STORE again.
- Then type in the phone number again... this works, though there's probably a way to do it w.o putting in the number twice... but since it works, don't sneer at the free advice :) LOL.
- Then click Store
- Then type in the NAME
- Then Store.
Done. Repeat for other names/numbers. Now that you have it down, you can figure out how to do this without entering the phone number twice... but since I have a busy day, I'm just doing it this way.
Best wishes!
Posted on Jul 29, 2008
SOURCE: Telefunken TTV 2126 fac
Replace e-prom.
Posted on Feb 27, 2009
SOURCE: Olevia Hi Def tv 242TFHD, won't turn on. Power
yes the capacitors your looking for are a 1000uf , 1500 uf , and on the other side of the heatsink a 680 uf. the tops will be slightly bowled. replace those with same type !not brand!, and youll be happy.(same thing happened to me, less than 2 years old also).
Posted on Dec 04, 2009
  • 7 Answers
SOURCE: My Reset button wont reset
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Posted on Mar 28, 2010
My daughter forgot the password that she put on our AOC TV LC32W063. That code blocks the video all the time . How can I remove that code or reset the TV?
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Jan 05, 2014 | AOC LC32W063 32 in LCD TV
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
My telefunken tv works and I can watch tv by using the buttons on the side of the tv, but when I try to use the remote it only registers that i'm pressing 1... no matter what button i press. any
AH! I have fixed a lot of remote controls in my career. I would suspect something may have got spilled onto the top of the remote and got inside under the front rubber like buttons you press.
You have a few clear choices here: find a tech or a shop who can take the remote apart(they can also test the remote) and clean it properly and put it back together.
I would do that before looking to buy another remote---if the side buttons work the set is ok--issue is with the remote.
Please use the make a comment button on this page if you want more information or help.
Apr 29, 2012 | Televison & Video
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
I hope this helps.
Apr 21, 2010 | AOC L24H898 24 in. LCD TV
The aoc l22w898 tv is stuck on the screen the syas initializing, please wait. It worked fine for a few days but now it wont get past this screen.
- Press Menu
- Press 991
- Go down to Memory recall and press enter
- It will ask you "ARE YOU SURE"?
- Select "Yes" and press enter
- It will take you back the menu screen, turn off the TV and turn it back on user_offline.gif quote.gif
Dec 03, 2009 | AOC L22W898 22 in. LCD TV
press the display button on your remote for about 5secs. until the lock disappear then turn your unit off on the remote then unplug it.
Jul 21, 2009 | Televison & Video
Toshiba 42h82
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
1) Press MENU button on TV.
Adjustment mode
Service mode
S Data
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Unlock telefunken model ttv293A
the remote for my Telefunken ttv293A, is damaged.
How do i switch to dvd input?
Sep 02, 2008 | Televison & Video
Telefunken TV, Model TTV-215(C)
Hi all you Telefunken TTV-215 owners. My tv did this to. Panasonic in Bloemfontein helped me by phoning Telefunken and getting back to me within 10 minutes. All you have to do is turn your tv on and then press and hold the F button on the remote and while doing this press and hold the MUTE button also. If this doesn't work try olding down the display button on your remote for +- 5 seconds. If still no results try phoning your nearest Panasonic dealer.
Sep 01, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
