Question about LG Televison & Video
My LG TV IS SHOWING A MESSAGE IN THE MIDDLE OF THE SCREEN EVERY 2-3 SECONDS IN A BOX THAT SAYS: SIMPLINK Please Try Again
In the left corner of the box is also a triangle with orange and black inside of it. My cable troubleshooter says it is a problem with the TV. Can you help?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Go into you menu and options and turn off simplink.
Posted on May 08, 2017
Why does my Mitsubishi WD-65737 TV go black for 4 or 5 seconds then picture comes on again with the top left corner says "Cable Box".
Replace service cords, as they might be getting worn and loose. It does sound like that to me. Bad coaxial cables
Apr 10, 2015 | Mitsubishi WD-65737 65"" rear projection...
Why dose my lg lcd tv keeps disconnecting from sky box
Loose cable, or getting a signal from another input, or picking up an infrared signal that clashing. These are just a few answers, and they don't exclude either a TV or a Sky box fault.
Try switching off the Simplink features on the TV and see if that helps.
Sep 07, 2014 | LG Televison & Video
I have an lg 52LG70, 3 years old. recently, after i hit the on button, the tv will come on, but within seconds, fades to black, starting at the corners, moving to the middle. still have audio. a few...
Tv have 2 long LCD inverter boards it probally require replacing.These 2 long LCD inverter boards job are to provided the tv LCD screen panel to have a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Mar 22, 2011 | LG 52LD550 52Inch 1080p 120Hz LCD HDTV...
How do you save the simplink settings on LG tv. When I get the setting up to have my home cinema system linked to the TV it works great... However, when the TV is turned to standbye, and you break the...
I am currently having the same problem, there is a setting (which I have not found again yet) to change into a mode to enable quiet startup, so you dont accidentally turn devices on when their volume is up loud, I believe this could be the cause but as I said I am still looking for that setting! Constantly have to keep changing speaker output in Simplink every switch on
Mar 04, 2010 | LG 42LG30 42 in. LCD HDTV
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
Tv guide on our LG tv
If, when selecting the guide, the entire screen is black (except for the preview in the corner), then the digital main board has gone bad and will need replaced.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG 32LX1D 32 in. LCD Television
Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
435 people viewed this question
