Question about Craftsman Garden
I have a craftsman lawn tractor. It starts and runs until I egage the mowing deck. Then it stalls.
  • Craftsman Master
  • 10,111 Answers
Id check for seized bearings or spindles on the mower deck
Posted on May 08, 2017
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor stalls
When it stalls, does it die suddenly, as if you turned off the ignition? If so, there may be an electrical problem. Heat causes plastic circuit boards and connectors to expand, and if there's a crack it could open a circuit. One way to find it -- get a can of circuit chiller spray (like this). Run the tractor until it's hot, and stalls. Now spray various ignition parts, one-by-one, testing the tractor after each spray. I'd try the ignition switch, the relays, and the connectors around those. If it seems to fix it, repeat the experiment to be sure. Then replace the bad part.
If it stalls gradually, like it's being dragged down, then it could be mechanical friction - like a bearing or shaft that's heating up and expanding. If you drive around without the blades on, does this still happen? If so, that eliminates the mower deck with its spindles and pulleys as a cause, and suggests it could be the engine. Good luck!
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
12.5 hp craftsman runs fine for only the first 1/2 hour or so
You are so right, the coil has a small crack the opens up as it heats up. You know the old saying as metal heats it expands this causes a open circuit.
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engins starts and runs when mowing will backfire and stall.
I am not sure what time of lawn mower this is, but if the blade is directly tied to the motor, usually the belt will just slip if not, but if this is directly connected to motor, it might have jumped timing. If this is not the case, inspect under the mower deck, and determine if there is something jamming the blades against the deck or if their is something bound around the blade, this can cause more strain on the motor, which could result in the symptoms your experiencing.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 18.0 HP 42" lawn tractor stalled while mowing tall grass cleaned out the bottom of it and now it will not start again no turn over, clicking just nothing pls help! Very easy terms this is a woman...
Perhaps one of the safety interlock switch leads got disconnected when you were cleaning out the plug. Look for two dangling ends with connectors and reconnect any you find.
Apr 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
