Question about Electrolux Washing Machines
I have a Electrolux Washing machine EWFLW65HTSAA with an error code E53 and so doesn't start any cycle. Any advice on what part needs replaced to fix this?
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
e-Guru
  • 3917 Answers
SOURCE: error code e40 on my washing machine electrolux
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
Posted on Aug 06, 2009
  • 160 Answers
SOURCE: e 20 error code on electrolux inspire washing
e20 usually means not draining...check for blocked filter, or obstructed/ faulty pump unit...
Posted on Dec 21, 2009
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
Error 53 on electrolux front load model # EIFLW50LIWO
The E53 error code indicates low voltage to speed control board. Check the wiring between the main control board and the speed control board and if the wiring checks ok then replace the speed control board.
Jul 05, 2016 | Electrolux Washing Machines
What does error 90 Mean on an Electrolux Ewf 1087
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Feb 22, 2016 | Electrolux Washing Machines
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
Dado
Feb 12, 2015 | Electrolux EW1000i Front Load Washer
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
What do error codes E51, E52, and E53 indicate?
This link lists the error codes for your cooktop: Needapplianceparts com
Specifically, it's a "sensor break" in your front and center burners.
The solutions they recommend:
* Verify element temperature sensor is correctly connected to the generator circuit board
* Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature
* Replace associated generator circuit board
Jan 12, 2014 | Electrolux 30" Electric Hybrid...
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
The door is opening even when the machine is on.Error code 50 comes on display
It ispossible that the error comes because the door was opened during the cycle. Remove power for sometime to reset . Now check the door lock and safety on feature while the cycle starts. If there is fault in this link the program will show an error.
Check the lock : http://www.espares.co.uk/advice/washing-machines/a/7/1207/how-to-replace-a-washing-machine-tumble-dryer.html
Jun 28, 2012 | Washing Machines
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
How to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Mar 14, 2009 | Electrolux Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
